need head and intake advise
I have a 89 with a 347 eagle stroker shortblock and a e303 cam, 1.7 rockers, but it has factory e7 heads and fact. intake. I want alum. heads and new intake, which brand makes a kit or what combo will help me most hp wise and are the cheapest! Any brand im not picky just poor! lol
Well whoever build that 347 is retarded to wast the time in putting the e7's back on. AFR,Trick Flow, and Edelbrock are usually the most used. You can get top end kits from 2000-2500 that are decent but you can match a combo together to make power. What kind of budget do you have?
This is good advice, look at heads in this size range, maybe even 205 depending how aggressive you're looking to go. If you want to do it right pick out the heads and intake you want and look into getting a custom grind cam to maximize your setup.
Daddys Girls GTs
09-14-2015 08:46 PM
