I'm New!
Old Feb 9, 2009 | 12:18 AM
TrimDrip's Avatar
TrimDrip
FudgeDrip
get the small bellhousing
Old Feb 9, 2009 | 02:00 AM
302army187's Avatar
302army187
dont forget that with a convertible you will need atleast a 5 point welded in rollbar to go faster then 13.49.
i would deffently build up that C4, and throw boost at that car. upgrade the reared too, and youll be flying.
Old Feb 9, 2009 | 04:46 PM
boosted AWD's Avatar
boosted AWD
Originally Posted by Chadwick86
Welcome to the site! Ford racing sells A/C delete kits for $50. As long as the C4 is a 1970 and later model you should be good. There are two types of C4's, big bellshouseings (164 tooth) and small bells (157 tooth). If it is a small bell you'll need a 157 tooth 50oz flywheel for your car. Also there are pan filled C4's, and case filled. Don't know which is better. I hope I was some help, have fun with the build
http://www.jegs.com/p/Ford+Racing/752156/10002/-1
1. how can i tell whether his mustang has a big bell housing or small bell housing without removing the transmission?
2. If it does have the big, everything should be fine aside from moving the crossmember, right?
3. if it does not have the big bell housing, do i just
a) buy a 157 tooth flywheel and it'll bolt right up?
b) and to put the aod in the '70, do i just put a 164tooth flywheel on that ho?
c)do the flywheels interchange?
Old Feb 10, 2009 | 08:53 AM
boosted AWD
bump! answer my questions!
Old Feb 10, 2009 | 10:23 AM
Slo5oh's Avatar
Slo5oh
Banned
Why do you guys always jump to power adders? Build it the white way, the right way and go N/A.
Old Feb 10, 2009 | 11:00 AM
302army187's Avatar
302army187
uhhhhhhhh........... what?
Old Feb 10, 2009 | 11:09 AM
FivePointOhh's Avatar
FivePointOhh
in limbo
racist are we?
Old Feb 10, 2009 | 11:16 AM
Slo5oh's Avatar
Slo5oh
Banned
nope, its a saying, but if i were....would you take issue with it?
Old Feb 10, 2009 | 01:45 PM
Alex-7's Avatar
Alex-7
I don't know anything about C4s.
But wanted to remind you that your going to need a mass air conversion for that car. Just because I didn't see you mention it....
Old Feb 10, 2009 | 02:08 PM
boosted AWD
I did know this, thank you for mentioning it though.
