electric window problem
Old Feb 21, 2009 | 08:57 PM
5.0muscle's Avatar
5.0muscle
Unhappy electric window problem
The passenger side window in my 1990 suddenly stopped working using either the D/S or P/S switch. There was no noise when i tried either switch so I thought( wrong ) that it was the motor. I hooked it directly to the battery and it worked fine up or down. Is there a fuse in the door I can check? Am I correct in thinking that the switch is not likely the problem, due to the fact that the window stopped working with both switches at the same time? Help Please!
Old Feb 21, 2009 | 09:21 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
pending on which switch usually controls the ground...which is often the master switch, it may have a bad master switch or passanger switch
Old Feb 21, 2009 | 09:39 PM
droptop302's Avatar
droptop302
Wink
My bad need to get some sleep. lol
Old Feb 21, 2009 | 09:41 PM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
Originally Posted by droptop302
Most likely window motor, take off door panel and try to put direct power to the motor if it does not work its the motor.
Reading owns you
Tivo304
Aug 28, 2023 12:19 PM
articman
Jun 21, 2018 11:45 PM
zanemoseley
Sep 6, 2015 12:58 PM
cbird1177711
Sep 3, 2015 08:43 PM
5.0 kevo
Sep 3, 2015 06:24 PM
