what intake please
Old Feb 24, 2009 | 05:44 PM
Jrichber95GTS's Avatar
Jrichber95GTS
Default what intake please
I am trying to find out what intake to go with. I have a 347 and am getting a new custom cam from camshaft inovations have a 75mm TB and MAF 255 fuel pump 195cc pro comp heads msd 6al box and at the moment 24lb injectors which i will most likely bump up to 30lb. I am just not sure if the rpm2 or the sytemax 2 is the way to go.
Old Feb 24, 2009 | 05:54 PM
Joel5.0's Avatar
Joel5.0
Did you supply the build sheet for the cam already?..... if not, you can leave that item open for Jay's suggestion based on your goals (performance and driveability wise) + it's a very key component for the cam design. TFS box, Vic Jr. + elbow are good alternatives you may want to check. LUK
Old Feb 24, 2009 | 07:28 PM
Jrichber95GTS
awesome will try that thanks
jwog666
Dec 27, 2021 08:09 PM
daltron
Apr 28, 2016 08:10 PM
bradleyb
Nov 27, 2015 07:50 PM
Dokilar
15
Oct 16, 2015 08:13 PM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
