Head question
Old Mar 4, 2009 | 10:57 AM
nacanitihs's Avatar
nacanitihs
Default Head question
ok im in the market for new heads. some of you may have read my other post about gt40s
but how are these? TRI State Cylinder head Tri-Pro 5.0
Single Head Bare
60cc Combustion Chamber
190cc Intake Runners
Phosphor Bronze Valve Guides
3/8" Screw-in Studs & Guide Plates
2.02" Intake Valves
Stainless 1.600" Exhaust Valves
Performace Springs Good To .550" Hyd. Roller
*130 psi @ 1.800" (closed)
*340 psi @ 1.258" (open)
with 1.6 RR
i can get a real good deal on these..
let me kno in comparison to gt40s
Old Mar 4, 2009 | 11:02 AM
FivePointOhh's Avatar
FivePointOhh
in limbo
looks like another pro comp head. i know tristate cylinder has those crappy flo-tek heads. is that the ones you are referencing?
link to the page?
Old Mar 4, 2009 | 11:04 AM
nacanitihs's Avatar
nacanitihs
here is the link to the heads http://www.tristatecylinderhead.com/...products_id=29
and no they rnt the flotec heads
but they are from a private seller w/ 3k miles on them
LMK
Old Mar 4, 2009 | 12:35 PM
w8less's Avatar
w8less
they are somewhat local i might see if i can give them a call and check them out
Old Mar 4, 2009 | 03:07 PM
Portmaster's Avatar
Portmaster
Well they will outflow a GT-40 or GT40p but you may (probably) run into Piston to Valve clearance issues with the 2.02 intake valve. I'd be looking around for a used set of Trick Flows, AFR's. Edelbrocks.
Old Mar 4, 2009 | 06:15 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
how much does the private seller want for them??
Old Mar 4, 2009 | 06:26 PM
nacanitihs's Avatar
nacanitihs
he wants $350. they are still on the car
Old Mar 4, 2009 | 07:30 PM
Explosive's Avatar
Explosive
I'm with port on this one.
Vrooom
Feb 21, 2016 05:25 PM
EASTIDEE123
Sep 14, 2015 03:52 PM
cbird1177711
Sep 2, 2015 08:51 PM
cbird1177711
Sep 2, 2015 04:12 PM
