Squealing Belts
Old Mar 19, 2009 | 08:30 AM
hollcraft1's Avatar
hollcraft1
Default Squealing Belts
When I start my 87 GT, The belts make a squealing sound. Before I did anything I wanted to know what it could be. Is it the belt or pully, I don't know. What can I do to find out what it is?
Old Mar 19, 2009 | 10:08 AM
calfroper_06's Avatar
calfroper_06
more than likely you just need to replace the belt.When you start it does it squeal then stop or does squeal all the time
Old Mar 21, 2009 | 01:07 PM
Musti94's Avatar
Musti94
If you going to replace the belt, buy the Goodyear Gatorback belts. I had issues with squeaky belts in the past with my 2 mustangs, and these belts resolved that issue. The teeth on the belts only go about halfway into the pulley grooves, which I believe helps avoid the squeaks.
Old Mar 21, 2009 | 01:15 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
either the belt is glazed or tensioner is weak, if tensioner is okay go for a gatorback belt.
vargas
Jun 17, 2017 12:17 PM
FivePointToTheOh
Sep 29, 2015 12:53 PM
rafotree
Sep 22, 2015 03:55 PM
ccdguy
Sep 19, 2015 05:20 PM
