upgraded gear, difference feeling
Old Mar 29, 2009 | 02:11 PM
redpony88's Avatar
redpony88
shouldn't have anything to do with the internals, the gears are set to a case not to the car so if the whole case is swapped it should be fine, i've done it before as well like on my 83 i pulled my 8.8 from my 88 and put that in there no way was i wantin to stick with the 7.5.
Old Mar 29, 2009 | 02:13 PM
OnyxCobra's Avatar
OnyxCobra
Gotcha, it's possible I have it confused with something else.
Old Mar 29, 2009 | 04:28 PM
AdderMk2's Avatar
AdderMk2
Banned
you will have to notch the backing plate mount on the axle to clear your ABS sensors IF you are swapping in a fox 8.8
Old Mar 29, 2009 | 04:47 PM
86HOGT's Avatar
86HOGT
I think they all have SN95s...
Old Mar 29, 2009 | 05:03 PM
redpony88's Avatar
redpony88
well the diff i'm getting is from a new edge, my friend got it for his drag fox, so i'm assuming that i shouldnt have to do much to make it fit mine other than put my axles in. otherwise my diff is going into a 86 gt.
Old Mar 29, 2009 | 05:42 PM
Timspony's Avatar
Timspony
SVT Section Moderator
Good luck with the 4.10's! ...will wake your car right up!
Old Mar 30, 2009 | 02:24 AM
86HOGT's Avatar
86HOGT
I think the New edges have 4 wheel ABS which mean's the brake lines are routed differently but now that I think about it, it may not be a problem. Also, your track width will be 1.5" wider than what you have now, again, it's probably a non issue running that wide on the SN95 but those axles are 1.5" wider each side than the Foxes.
Old Mar 30, 2009 | 07:43 AM
kweb288's Avatar
kweb288
i went from 2.73's to 4.30's in my fox.... WOW thats all i have to say. O and i have a 5 speed to, that sees some highway cruising, it isnt as bad as a lot of people make it out to be
Old Mar 30, 2009 | 09:48 AM
Portmaster's Avatar
Portmaster
Originally Posted by OnyxCobra
I'm pretty sure even if you're swapping diffs you'll still need to redo the gear alignment...
Nah, It's just pull out the entire differential and do the swap
Old Mar 30, 2009 | 11:14 AM
AdderMk2's Avatar
AdderMk2
Banned
hes using his stock axles... there wont be any change in his track width
drfister
May 3, 2018 10:38 PM
yourmom6990
3.7L V6 Technical Discussions
Oct 14, 2015 10:08 PM
musnicki
Sep 23, 2015 07:11 AM
IronRaptor
Sep 9, 2015 08:10 AM
5.0 kevo
Sep 3, 2015 06:24 PM
