Quick N/A question
Old Jul 31, 2009 | 07:48 PM
60trimGT's Avatar
60trimGT
Originally Posted by OnyxCobra
considering how cheap cams are I would definitely throw one in there while you have everything else apart for the extra power gain...
i was thinking trickflow stg 1 cam. but i dont want it to hurt gas mileage much. the car will be a dd
Old Jul 31, 2009 | 07:56 PM
NoGo95GT's Avatar
NoGo95GT
I lost 2 mpg by installing a cam. I used the Trickflow Stg-1. It's a great cam. It sounds good, makes good power and is cheap. But you will trade low rpm torque for high rpm, horsepower. It's your call....
Old Jul 31, 2009 | 08:01 PM
OnyxCobra's Avatar
OnyxCobra
Yeah kind of a tough call for a daily driver, the best thing to do about gas mileage is just not check it lol. Seriously though are you worried that much about it even after doing all these other mods?
Old Jul 31, 2009 | 08:02 PM
60trimGT's Avatar
60trimGT
well i dont see it being necessary. the car will only see track time maybe twice a month. i think the 100 shot would compensate for the cam
Old Jul 31, 2009 | 08:03 PM
60trimGT's Avatar
60trimGT
the only other mod i think would hurt mpg are the gears right? the h/i swap wont hurt them since its allowing the car to breath better?
Old Jul 31, 2009 | 08:33 PM
NoGo95GT's Avatar
NoGo95GT
That's a great point that someone MIGHT assume. Yes, the heads and intake will increase airflow. But in order to support the new airflow, the motor will need to use more fuel, which in turn uses more gas. I neither lost nor gained mpg by having the H/I(I take that back, I gained about 1mpg). In theory gears will not waste gas mileage. In fact they should improve it. With the stock gears, you need more throttle to get into your powerband. But with gears, you use less throttle to get there, as the gears "multiply your torque" output. But with the gears, you will want to get on the throttle all the time. So all that gas saving goes to waste. If you do a lot of freeway driving and have 4.10 gears, then mpg will suffer because you will be at a higher rpm for cruising. I hope this makes sense.
Old Jul 31, 2009 | 10:43 PM
OnyxCobra's Avatar
OnyxCobra
Yeah gears can help MPG around town but will pretty much always kill your highway mph. Also I agree with NoGo, the more air your engine takes the more fuel that will be needed to keep proper a/f ratio.
And yes obviously a 100 shot will more than compensate for a cam, but both would be even better.
Old Aug 1, 2009 | 02:24 AM
60trimGT's Avatar
60trimGT
ah it makes sense. i don't do alot of highway driving at all so im not worried to much about the gears. and as for the cam+100 shot i'm sure it would be awsome. i just dont want to get into it just yet if that makes sense. but thanks for the info onyx and nogo you guys are really helpful
tmdm
May 2, 2021 02:49 PM
svfetter
Oct 5, 2015 11:39 AM
Big Al's 03
Sep 15, 2015 09:05 AM
Mustangmalo
Sep 6, 2015 05:22 PM
