92 5.0 turns but wont start
Old Aug 26, 2009 | 01:15 PM
stangowner8687's Avatar
stangowner8687
Default 92 5.0 turns but wont start
would my engine still crank over if the cam is broken? this is what im thinking is wrong
changed/checked
fuel pump
fuel pump relay
fuel filter
fuel pressure
electronic ignition mod.
distributor
MAF sensor
Old Aug 26, 2009 | 01:40 PM
stangowner8687
oh and i also wanted to add, if this is the problem, i was wondering if a 351W cam and heads would fit on with no adjustment, considering i have bbk headers.
Old Aug 26, 2009 | 01:55 PM
TrimDrip's Avatar
TrimDrip
FudgeDrip
even if the cam is the problem, it would most likely the bolts that hold the timing chain to the cam have broke off in it.
I assume you forgot to put the coil on the list?
Old Aug 26, 2009 | 02:12 PM
kennebellgt's Avatar
kennebellgt
Your cam is broken? and can you hear the fuel pump prime when you turn the ignition key to on?
Old Aug 26, 2009 | 03:52 PM
Timspony's Avatar
Timspony
SVT Section Moderator
I'm thinking TFI Mod. or Fuel Pump....
Old Aug 26, 2009 | 09:32 PM
stangowner8687
i did change out the coil, the fuel pump does prime.
heres about how it goes, i jump in turn the key it cranks over and doesn't fire, before it would fire if i sprayed some starter fluid in the throttle body, when i changed the PCM it worked but the timing was off. so my brother and i adjusted the timing. and when i jumped in i said "we all clear!?" he said yes when i went to start it up he looked like he just been shot. i get out to find that he left the ratchet attached to the crank pulley so im guessing it spun around and smacked the cam pulley. since than we can't get it to start with or without starter fluid and the dealer ran 3 hours worth of diagnostics and said in order to find the problem they will need to check the compression and tear it down. i rather them not.
Old Aug 26, 2009 | 09:50 PM
SonicBlueFiveSlow's Avatar
SonicBlueFiveSlow
There is no cam pulley...if the ratchet spun around and smacked anything, it probably hit the water pump pulley.
Old Aug 26, 2009 | 09:56 PM
TrimDrip's Avatar
TrimDrip
FudgeDrip
stick a screwdriver in on of the wires while turning it over to make sure you are getting spark.
If you have spark, go back and check the firing order by a book.
I would do what Matt mentioned and make sure the distributor is installed correctly.
If everything you listed has been replaced, I would look at getting a new computer.
Also, when the fuel pressure was checked or ADJUSTED, you did use the bleed off on the tester to set it correctly?
Old Aug 26, 2009 | 09:57 PM
mattdel's Avatar
mattdel
your dealer ran 3 hours worth of diag and didnt find the problem? dont go back there.
the ratchet deal is 100% a coincidence. my money is on the distributor/TFI/PIP
Old Aug 26, 2009 | 11:33 PM
stangowner8687
well 1st off i want to say yes the waterpump pulley rather than the cam i am aware thats nonexistant. 2nd the dealer did replace the computer afterwards it ran but with crappy timing but we drove it home from the dealer (7miles) and we left it set for 3 days. at that time we adjusted the timing, he left the ratchet attached "BAM" it smacks my waterpump/fan pulley, and now doesnt start but let me add that when we let it sit for those 3 days i didnt think to fire it up again before doing the timing so i've no idea. could they really have given me a bad comp? again if my cam is damaged would i be able to use a 351w cam and heads with my stock intake and bbk headers? but only if thats the problem. its still at the dealer so i cant just run out back and check my dis. and plugs to see if its not properly in but it all turns like its suppose to
