overheating
Old Sep 3, 2009 | 01:42 AM
COBRASNAKE1's Avatar
COBRASNAKE1
Question overheating
i have an 89 gt that i bought 4 years ago with 90,000 miles. i recently changed the thermostat, then the car started overheating. i then assumed that i could of put the thermostat backwards even thought i got the wrong temperature thermostat, but i didnt it match the old one. my next option was to put back the old thermostat, but made no difference; it still overheates!!
Old Sep 3, 2009 | 08:18 AM
AdderMk2's Avatar
AdderMk2
Banned
did you make sure you burped all the air out of the cooling system? did you refil the car with a 50/50 mix or did you pour straight coolant back into it
Old Sep 3, 2009 | 02:53 PM
COBRASNAKE1
how do u burp the air out???
Old Sep 3, 2009 | 05:39 PM
NoGo95GT's Avatar
NoGo95GT
When the car is cool, pop off the radiator cap. Let the car warm up. You will see the coolant flowing and see it start to rise. If there is air in the system, you will see tiny bubbles popping When it starts to overflow, throw the cap back on. If you saw small bubbles still popping up, repeat, but only when the car is still cool. Now would be a good time to replace the radiator cap too. Also, how hot is the car getting?
Old Sep 4, 2009 | 12:43 AM
COBRASNAKE1
i just replaced the radiator cap today n still the same. it get to a line before it hits 270. could it be the water pump??? thanks for the help
Old Sep 4, 2009 | 05:07 AM
AdderMk2's Avatar
AdderMk2
Banned
dude, its too late for your motor... time to take it apart
Old Sep 4, 2009 | 07:43 AM
86HOGT's Avatar
86HOGT
What a rook move
Old Sep 4, 2009 | 12:19 PM
1ATony's Avatar
1ATony
Former Sponsor
When you fill a car back up with antifreeze after doing a repair like that. Like some one stated earlier take the radiator cap off.
Let the car get warm turn the heat on inside to get everything circulating,and when you see the fluid level drop inside the radiator,keep topping it off until,it's full and stops taking antifreeze.
Put the cap back on the radiator and top off the overflow and you should be allset.
Tony
BOB ROME
Jul 26, 2023 01:54 PM
mungodrums
Sep 29, 2015 09:18 PM
yourmom6990
Sep 14, 2015 10:52 PM
MusicCity615
Sep 12, 2015 07:05 AM
96stang3.8
Sep 10, 2015 06:42 AM
