Blower whine but theres no blower?!?
Man when you put it that way, it REALLY makes them look bad. LOL
they had cars getting 45+mpg in the 80s...
The only advantage of gear drives is that it maintains consistent timing at high rpm, no chain stretch or deflection. That said, most pushrod engines that turn high rpm don't need a gear drive, I think both NASCAR Cup engines and NHRA Pro Stockers are running timing chains...though the Pro Stockers might run gears. Timing gears are also used on some OHC high rpm race engines like Formula 1, but that's cuz it's basically impossible to get a chain to function correctly at 18,000rpm. But gear drives are heavy, noisy, complicated(in OHC setups) and can be hard on parts.
The only advantage of gear drives is that it maintains consistent timing at high rpm, no chainction. That said, most pushrod engines that turn high rpm don't need a gear drive, I think both NASCAR Cup engines and NHRA Pro Stockers are running timing chains...though the Pro Stockers might run gears. Timing gears are also used on some OHC high rpm race engines like Formula 1, but that's cuz it's basically impossible to get a chain to function correctly at 18,000rpm. But gear drives are heavy, noisy, complicated(in OHC setups) and can be hard on parts.
If a belt drive will work, yes. The problem with the extremely high rpm(currently 18,000rpm limits, several years ago they were pushing 20,000rpm) seen in F1 engines is that at those kinds of rpms there's a HUGE amount of force on the belts, and stretching/breaking becomes a major issue, as well as all kinds of harmonics that cause the belts to vibrate and screw up timing. Formula 1 engine rpm is probably the only real justification for a gear drive.
KingRando
10-01-2015 11:16 AM
mrmrultimate
Texas Regional Chapter
09-10-2015 09:43 AM
