Ppg paint
Old Oct 6, 2009 | 12:20 PM
86_GT_Mustang's Avatar
86_GT_Mustang
Default Ppg paint
Doose anyone know the mic for ppg single stage paint? Base thinner and hardner?
Old Oct 6, 2009 | 07:48 PM
5.0stanger's Avatar
5.0stanger
I would imagin it is like others, 4 parts paint, 2 parts thinner, one part hardener. That is how I mix all my 2 stage for the most part. Do a google?
Edit, I meant to put one half part hardener..oops!
Old Oct 6, 2009 | 08:58 PM
5.0stanger's Avatar
5.0stanger
found this....
Mixing Ratios: Standard Option
Reduce Delstar® with the DTR Reducer best suited for shop conditions and add Delthane® DXR80 Hardener using the following ratio:
DAR Color : DTR Reducer : DXR80
8 : 3 : 1
Pot life of the mixture is 8 hours at 70ºF (21ºC).
DU5 Option
DU5 may be used for faster dry and better buffing:
DTR or DAR Color : DT* Reducers : DU5
4 : 1 : 1
*DT Reducers may only be used with DU5 and only with the 4:1:1 ratio.
Flexing Option
DAR Color : DTR Reducer : DX814 : DXR80
8 : 4 : 2 : 1
what line of paint? here is where I found it...
https://buyat.ppg.com/refinishProduc...8-ea5e5965beef
Old Oct 6, 2009 | 10:09 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
4-1 -1 is the most common scenario, but call your local ppg supplier, when I painted the underside of my hood, that was the ratio
guitarman376
Oct 11, 2015 01:47 AM
Oct 1, 2015 09:29 AM
mungodrums
Sep 28, 2015 10:54 PM
GLOCKer
Sep 28, 2015 07:36 AM
mustangchef
Sep 4, 2015 08:08 PM
