i have a 347 short block with world products windsor jr heads running 10.25:1 compression. gt40 upper and lower with 1/2in spacer. e cam,70mm TB, 75mm maf, cold air, 30lb injectors,long tubes, roller rockers, full exhaust, 373s and nitto drag radials. the car is a stick with a pro 5.0 shifter. ways 3100lbs. what do you guys think i will run next spring when i go to the track?
dam i forgot about that again. quick question. for questions like the one i just asked, where should i post it? i like this forum. its a great tool. i dont wanna **** off anyone.
