Typhoon intake
Old Dec 16, 2009 | 01:48 PM
stevebrack23's Avatar
stevebrack23
Default Typhoon intake
I see a few guys on here that have em and i was just wondering how well do they perform do you suggest it or go with something better. I have a unmolested 302 with the stock air silencer still in it and the xmas money will be coming in soon. What do you guys suggest?
Old Dec 16, 2009 | 01:58 PM
FivePointOhh's Avatar
FivePointOhh
in limbo
buy heads first. dont waste time on intake or cam without having heads done first.
Old Dec 16, 2009 | 02:06 PM
stevebrack23
I was doing some research on that as well. Ive looked into patriot heads, know nothing about them and also looked at the e-street heads as well. Not quite sure where to start. Another question is will the stock upper and lower keep up with the heads?
Old Dec 16, 2009 | 02:14 PM
FivePointOhh
in limbo
there will be some limitation but not quite as bad what your heads are doing right now. if you were to swap out in stages i would always do heads first.
look into TW heads.
Old Dec 16, 2009 | 02:55 PM
ctgreddy's Avatar
ctgreddy
i've heard some good and mostly bad about patriots. don't go with procomps. the estreet heads I've heard good things about. look around for some used afr165's that might fall in your price range.
when you do go intakes the spyder is only good for 2 things imo; forced induction and looks. on most na motors it won't be very good because of the high power band. some to consider would be a gt40 if you're on a budget. or a nice eddy rpm II or systemax II
Old Dec 16, 2009 | 03:00 PM
stevebrack23
Ive heard the afrs are the way to go yea i am on a budget but if it takes saving some money and thats the way to go. Also what about the trickflow upper and lowers how do you guys feel about those?
Old Dec 16, 2009 | 06:01 PM
luckythirteen13's Avatar
luckythirteen13
check corral, you can get used afrs at a great price. and i had great luck with the typhoon intake and afr 165 heads
jwog666
Dec 27, 2021 08:09 PM
daltron
Apr 28, 2016 08:10 PM
bradleyb
Nov 27, 2015 07:50 PM
Dokilar
15
Oct 16, 2015 08:13 PM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
