inspection help please!
It does say gt on it. I suppose that is an indication that it is a 302, though the seller told me he did put gt-40p heads on the engine. Is there any other means of identification? I dont guess its a big deal because Ill enjoy it either way thanks for all the help!
Of course it is a 302. A 306 is simply a 302 with enlarged pistons. Only 0.03 inch enlargement of the piston head (diameter) yields an extra 4 cubic inches of displacement.
The GT on the cylinder head indictes they are GT-40 heads. In your case, gt-40p.
The seller told you correct information as far as I can tell.
You may have a block from a cobra... or a regular mustang. Either way, you have the heads and intake that cobras were fitted with and either engine combo will make the same power not considering the cam.
Are you sure? There are two holes in the picture project resto posted above the casting plug.
One large and one small. The small hole is for the bolt that holds the thermactor tube on the back of the cylinder heads. The larger hole(also with threads) simply flows the gas to the thermactor tube. The reason this bigger hole has threads is because the bare cylinder heads are identical and when used on the other side of the engine, a threaded insert is put into this hole so you can mount your accessories like the alternator, etc.
Insidian
Carolina Regional Chapter
09-08-2015 05:33 AM
