Scan Codes, What to Do?
how long did you leave the battery unhooked before you reconnected it? if your KOEO TP voltage is .98 with the throttle closed, it should have deleted the code.
I just went through this with my 90, and the code 53 went away when I installed and set a new TP sensor, didn't even unhook the battery to reset the ECU. I am still getting the 82 and 84 codes for the EGR and I have an eliminator plate and a dummy EGR sensor. also getting code 81 (IAC circuit), and the IAC motor and valve are almost brand new.
lincolnshibuya
Dec 8, 2015 04:37 PM
