quick question ???
Old Feb 23, 2010 | 05:13 PM
nacanitihs's Avatar
nacanitihs
Default quick question ???
ok so hopefully tomorrow im going to remove the gt40p intake and install my trick flow street burner intake.
question here is should i actually run the spacer? its 3/8" thick. idk if i want the extra runner length as it it the street burner and not the track heat.. i kno it will reduce heat in the upper but i am still unsure.. mods are in sig.
plz give an explanation too thanx
Old Feb 23, 2010 | 06:23 PM
5.0kid's Avatar
5.0kid
It should help increase tq and thats really what gets you going not hp. I run a 1" spacer on my setup and wouldn't think of ever removing it. Hp is a direct relation to what your tq is. When you dyno a car on a chassis dyno it reads your tq and then it calculates the hp from it
Old Feb 23, 2010 | 07:10 PM
nacanitihs's Avatar
nacanitihs
ya i know all that and how a dyno works.
power = torque* rotational speed (rpm)
torque= tangential force * radius of the drum
force = mass*acceleration
i figured the longer the runners the more bottom end and less top end?
you have the track heat correct? the track heat has the shorter runners and therefore a 1" spacer will make it slightly more like a street heat thus giving you some more low end.
im just afraid that i will have too much bottom end and not enough top. as i have 3.73s
Old Feb 23, 2010 | 07:17 PM
AdderMk2's Avatar
AdderMk2
Banned
yup yup, longer runners usually equates to higher torque down low, and slightly less top end power (which can be negated in a tune, or with cam timing)
Old Feb 23, 2010 | 07:24 PM
5.0kid's Avatar
5.0kid
I have a street heat now, Had the track heat but the car responds better with the street heat for drag racing for me at least because really you make all of your run out of the 60' once you get going its all about just going straight, your gonna make all your time in the 60' so thats why I wanted more tq so that it comes out of the hole better which it does now.
Old Feb 23, 2010 | 07:25 PM
5.0kid's Avatar
5.0kid
really didn't lose anything up top actually ran faster on the top end because I got out quicker
Old Feb 23, 2010 | 08:00 PM
projectresto83's Avatar
projectresto83
M.A.D. Motorsports
I would run it. In theory you might lose a little top end power but how much do you really thing that is?
Old Feb 23, 2010 | 09:03 PM
nacanitihs's Avatar
nacanitihs
alright cool. ill run it. thanx guys
tmdm
May 2, 2021 02:49 PM
svfetter
Oct 5, 2015 11:39 AM
treesloth
Sep 28, 2015 07:03 AM
Big Al's 03
Sep 15, 2015 09:05 AM
Mustangmalo
Sep 6, 2015 05:22 PM
