What Stall Converter Are You Running?
You say you 'may see some track'. Since you won't be competing why get a racing converter? You have to drive the car everyday on the street. So, get a street stall. Why would you want to have to rev it over three grand just to leave a light?
If you want a race car, build a race car.
you obviously have no idea how a stall converter works, please dont give advice on them. the car will still move with just the motor idling even with a 5000rpm stall converter.
to the OP, i run a custom converter from art carr......and by custom i mean it was custom to my last motor. looks like the stall speed is going to work even better with the turbos then the vortech
We run a old JUNK as most say TCI 3800 it was behind the S/C engine and now the turbo as well works real good it is a bit lose acting on the street with 3.31 gears and a 28in tall tire but we have no issues at all with it ever and it has seen some abuse and lots of miles put on it and track passes. it is 6 years old or so. I have a customer that is running a Red Neck 4000 on the street and it also works VERY WELL I like it much better then my TCI and it was priced right. Make sure you run a BIG cooler with the C4 and if you can run a deep pan. Heat kills a C4 due to the low amount of fluid they run.
Luckythirteen13 gets a little hot under the collar it seems. Perhaps you would like a term paper detailing why I said what I said?
I have better things to do with my time. Suffice it to say, the purpose of a high stall converter is to increase the speed differential between the crank speed and the pump speed inside the converter. This maximizes the torque multiplication. This is overkill on a street car. Remember, the OP stated that his car "may see some track".
My statement about the light was 'loose' with reality, I'll grant you that, but the point of it is true. Anything over a 3000 stall on the street is overkill and a waste. Especially on a car that "MAY see some track".
for example, before i went to a one piece input shaft on my aod, i ran a 3000 stall custom made for my sc 302 making 461rwhp. it would flash just past 3000rpm. i sold the sc and stall to a guy when i built this motor. he put the converter in right away but not the sc. he told me it stalled at 2200 and not the 3000 i claimed. i told him to wait till he got the sc in and itll stall higher. sure enough, when the sc was put it, the converter stalled at 2900
a buddy of mine is running an sc with a 2600 stall. It actually stalls up to about 3 grand. That with a shift kit is the best mod I have seen him do for his times at the track yet. It launches like a beast on the street now too. The rest of the time it drives like a normal vehicle.
