door wont lock
Old Apr 12, 2010 | 10:54 PM
19stang88's Avatar
19stang88
Default door wont lock
so i just replaced my passenger's exterior door handle and now the door wont lock. the rod that locks and unlocks the door seems to get stuck. if i try to open it with the key from the outside i can't fully rotate the key to lock the door. any help please
Old Apr 13, 2010 | 11:23 AM
Bubba 95SN's Avatar
Bubba 95SN
Got power door locks? If yes, replace actuator. Bubba
Old Apr 13, 2010 | 05:59 PM
19stang88's Avatar
19stang88
yes i got power locks. can i just disconnect the actuator from the locking mechanism?
Old Apr 13, 2010 | 08:24 PM
stang8689's Avatar
stang8689
when the actuator gets stuck you cant move the rod a common problem just a rivet on the inside of the door if you drill it out and then you can move the rod thats what the problem was if not its something else
Old Apr 13, 2010 | 08:54 PM
19stang88's Avatar
19stang88
and if i remove that actuator then ill be able to lock and unlock my door from the outside?
Old Apr 13, 2010 | 10:06 PM
19stang88's Avatar
19stang88
ok thanks! i drilled the rivet that was holding the actuator and problem solved! I just need to unhook the actuator that is connected to the locking mechanism
Old Apr 15, 2010 | 01:16 AM
Shelty's Avatar
Shelty
yeah mine is just drilled out, you can hear it thunk around inside the door lol...
Old Apr 16, 2010 | 11:37 PM
87stampede's Avatar
87stampede
Hello, new here.
My drivers side door also won't lock. I have automatic locks but they don't work. What does the rivet look like that you drill out? I don't want to fix the automatic locks, i jsut want to be able to lock it with the key.
jerrytubes
Oct 23, 2015 12:11 PM
Sixer4Life
Sep 29, 2015 07:03 PM
Sep 25, 2015 06:58 PM
