Small miss...need ideas
Old May 4, 2010 | 11:41 AM
TrimDrip's Avatar
TrimDrip
FudgeDrip
Probably not if it had good compression.
Old May 4, 2010 | 05:35 PM
holyshift's Avatar
holyshift
Alright so new plug wires didnt help,its breaking up when you rev it,and when you drive it it breaks up...would a bad coil cause this?
Old May 4, 2010 | 08:57 PM
TrimDrip's Avatar
TrimDrip
FudgeDrip
If the plugs are flaky white you may have a fuel issue. Do you have a gauge on it and how is your fuel system set-up?
Old May 5, 2010 | 01:07 AM
dmarstroker's Avatar
dmarstroker
A coil can POSSIBLY be the issue. Have you checked the timing or checked for any vaccum leaks ?
Old May 5, 2010 | 05:44 AM
holyshift's Avatar
holyshift
The plugs I put in it were the wrong ones,autozone cross ref. them wrong so I put the autolites back in so theres no flaky look any more.Fuel pressure is good,fuel filter is clean,no vacuum leaks.
Old May 5, 2010 | 11:10 AM
Bubba 95SN's Avatar
Bubba 95SN
Never poke a hole into plug wires. If you do next time your hand or arm is near pierce... zap. If inclined to check wires just put your man hands in action and pull off by the plugs or cap.
Old May 5, 2010 | 04:07 PM
holyshift's Avatar
holyshift
^^Yea that just sounds like a bad idea,anyways I snooped around a bit and did find something.Check the video out
Now I replaced just that plug to see what would happen and the small miss at about 1500rpms went away,so made a little progress,still idles kinda funky but Iam gonna replace all the plugs and see what happens.Crazy,never seen a spark plug do that before.
Old May 5, 2010 | 07:26 PM
TrimDrip's Avatar
TrimDrip
FudgeDrip
I'm gonna take a shot in the dark and say that is the problem
Old May 6, 2010 | 05:47 AM
holyshift's Avatar
holyshift
Ha,it definatley runs better with all new plugs,but still a little fuzzy in the upper rpm's.I still cant believe those plugs did that,they only got about 50miles on them with a couple nitrous hits.Anyways lemme ask this,I have my plugs gapped at .035 for the nitrous,when Iam just cruisin the streets I have my timing at 16.Is that too much timing for that plug gap?Or should it be ok?
Old May 6, 2010 | 06:49 AM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
you'll be fine, mine is at .045
