306 will this setup work
Old 05-06-2010, 06:24 PM
michael50ism
michael50ism's Avatar
Default 306 will this setup work
im thinking of put my 1989 mustang gt in to a 306
the car has
BBK Cold air Induction System
70mm bbk throttle body,
Bbk underdrive pulleys,
Msd 8.5mm plug wires,
NGK iridium ix spark plugs,
Accel coil,
MSD Ignition Cap & Rotor Kits,
Flex-a-lite electric fan,
MSD 6 Series Ignition Boxe,
Mishimoto Aluminum Radiator
C&L 76mm Mass Air Meter
PRO 5.0 Performance Shifter
full exhaust
i found a Trick Flow Top-End engine kits provide dyno-proven power without the guesswork. Up to 360hp/350tq with this kit. http://www.latemodelrestoration.com/item/TFS-K514360350 and i will port and polish the heads and the manifolds with 19th high flow injector
should i get it
and this where im geting the Forged Pistons http://www.coasthigh.com/Ford-306-Fl...44-sf-f306.htm
michael50ism is offline
Old 05-06-2010, 07:47 PM
JD1969
Pro. B.S. caller outer
JD1969's Avatar
Why? A 306 is nothing more than 302 that has been bored .030 over. There is no real power advantage to a small overbore. The reason you bore an engine is to true up the cylinder walls, if the walls are ok there is no good reason to bore it out.
JD1969 is offline
Old 05-06-2010, 09:12 PM
Bubba 95SN
Bubba 95SN's Avatar
Es santa ana close to the North Pole?
Bubba 95SN is offline
Old 05-07-2010, 12:07 AM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
should i get it
bwaaaaaahaaaaaaaaaahaaaaaaa NO BUT THEN AGAIN IF YOU WANT ALL THE GUESS WORK taken out of ordering parts go ahead, you will not be even close to 360 rwhp, more like 260-275 ish
mjr46 is offline
Pyrate Dave
09-10-2015 07:30 PM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
M3hunter
09-05-2015 03:42 PM
cbird1177711
09-03-2015 08:43 PM
Quick Reply: 306 will this setup work
