ordering parts for build need opinions
http://www.summitracing.com/checkout/cart.aspx
starting my build, car is at my shop im hitting the engine bay with fresh paint, I need a K member, I have coilovers and tube A arms I dont want fitment issues with them however, they dont use the factory spring mounts.
Why do aftermarket K members move the wheels forward??
And tell me what you think of the parts?
I dont know which head studs or head gaskets to get. the trick flow gasket set has everything but should I go with better head gaskets??
My build thread will be opening up soon when i get pics up, and the motor just came out yesterday. I'm stoked!
http://www.summitracing.com/parts/CCA-19043-16/
http://www.summitracing.com/parts/FM...HOK-6225-1HKR/
http://www.summitracing.com/parts/TFS-51402001/
http://www.summitracing.com/parts/TFS-89024/
http://www.summitracing.com/parts/TFS-51400002/
in case you cant view my shopping cart in summit racings online catalog here are the part links individually.
TW 190 FAC
custom billet cam
http://www.teamzmotorsports.net/category_s/3.htm -k member
7/16 stud mount for the above mentioned heads
single plain carb style intake with efi bungs, 90* elbow and biggest TB, MAF you can get.90mm preferably.
42# injectors and 255lph pump
custom billet cam
and the trickflow gasket set comes with the good head gaskets.
http://www.summitracing.com/parts/TFS-51400914/
it has the:
Fel-Pro Performance Z10112 gaskets
and the Fel-Pro 1262 intake gaskets
this was the kit i bought when i did my hci swap
you will just need the upper intake gasket for what ever intake you and running. i also bought the rubber valvecover gaskets because the cork ones are one time use (usually)
also like protrickvic said go with the TFS FAC 190cc heads. why bother with the 170cc??
what intake do you plan on running?
TW 190 FAC
custom billet cam
custom billet cam
get ARP head studs
it has the:
it has the:
no these are really nice. prob one of the best imo with out going o-ring'd. they have the steal ring around each cylinder to prevent blowout. read the description on them. im sure these will hold up just fine against the s/c too.
my buddy has them and he's running n2o and i will be soon aswell. i have no worries about them at all.
and it is possible to notch your pistons w/ a dremel while they are still in the engine. just bring each up tdc and put tape over everything. make a template and grind away. make sure you vacuum often. there is a thread on here somewhere where someone did it if you would like to see pix
if you are running a stock 88 bottom end with standard 4v reliefs cut, then i wonder where you get your info? or are you assuming? if it is a stock bottom end, it will fit with the correct cam....custom cam, and if you do go with the 190's you should do custom since you'll want a smaller profile cam.
AMAlexLazarus
AmericanMuscle.com
21
04-04-2020 02:16 PM
09-02-2015 08:40 PM
