Pillar Gauges
Old Sep 12, 2010 | 10:38 AM
RTW0223's Avatar
RTW0223
Default Pillar Gauges
I am starting to look into getting gauges on my pillar. I am curious to what are some 'standard' gauges that people with 5.0's have, and what brand.
Old Sep 12, 2010 | 10:57 AM
Milton's Avatar
Milton
I have autometer "ultralite 2" series and I like them.
I like water temperature and oil pressure personally. Trans temp is another good one if your auto.
Old Sep 12, 2010 | 12:26 PM
RTW0223's Avatar
RTW0223
I have a 5 spd. I was looking at water temp, vacuum, and oil pressure. But wasnt sure. Also, I was looking at the auto meter ultra lite's too, but wasnt sure about either 2 1/16 or 2 5/8 should they be mechanical or electrical?
Old Sep 12, 2010 | 09:36 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
oil, water temp and possibly voltmeter gauge, vaccum/boost is a waste unless your boosted
Old Sep 13, 2010 | 08:15 AM
RTW0223's Avatar
RTW0223
what would be the advantage of having oil press, water temp, and vol if those are in my stock cluster? and i didnt mean vacuum/bost, just regular vacuum
Old Sep 13, 2010 | 11:59 AM
mjr46's Avatar
mjr46
C an H ...HMMMM COLD OR HOT?? HRMMMM HOW HOT?? Your OEM GAUGES ARE idiot gauges for all intents and purposes, they do not let you know how hot is hot, my mech gauges indicate exact temp and exact oil pressure VS L AND H ON stock gauges......oem doesn't give you an exact number just a general idea, with mech gauges you can see a prob coming....as for vaccum gauge, it serves no purpose nor reason to monitor as the 3 critical things are oil,water temp and volt/amps , knowing these three can help Driver not return on foot now spell it backwards if you want to add a 4th, add fuel pressure, I have oil pressure, water temp, volts, fuel pressure and nitrous pressure, I have the fuel pressure for obvious reasons = it goes hand in hand with running nitrous
Old Sep 13, 2010 | 12:38 PM
RTW0223's Avatar
RTW0223
Originally Posted by mjr46
C an H ...HMMMM COLD OR HOT?? HRMMMM HOW HOT?? Your OEM GAUGES ARE idiot gauges for all intents and purposes, they do not let you know how hot is hot, my mech gauges indicate exact temp and exact oil pressure VS L AND H ON stock gauges......oem does give you an exact number just a general idea, with mech gauges you can see a prob coming....as for vaccum gauge, it serves no purpose nor reason to monitor as the 3 critical things are oil,water temp and volt/amps , knowing these three can help Driver not return on foot now spell it backwards if you want to add a 4th, add fuel pressure, I have oil pressure, water temp, volts, fuel pressure and nitrous pressure, I have the fuel pressure for obvious reasons = it goes hand in hand with running nitrous
thats what i assumed. My oil pressure gauge likes to sit on zero sometimes... even though if that wetre true then my car wouldnt run lol. But i think Ill do the oil pressure, water temp, and volt. Probably gonna do either gears or gauges for X-mas. and whatever i dont do ill do in the summer
jwog666
Dec 27, 2021 08:09 PM
andrew1969
16
Jan 8, 2016 02:48 PM
SteelerNation82
Sep 16, 2015 07:11 AM
Pyrate Dave
Sep 10, 2015 07:30 PM
96stang3.8
Sep 10, 2015 06:42 AM
