carb and stock tach ?
Old Sep 16, 2010 | 11:43 PM
tohoopty's Avatar
tohoopty
Default carb and stock tach ?
anyone running a carb and using a stock tach.ive been trying to figure out which wires i would have to use to get it to work but im drawing a blank right now.
Old Sep 17, 2010 | 06:56 PM
68CSTANG's Avatar
68CSTANG
I did it for awhile. Ran the stock tach wire to the neg coil post. I can't remember the color of the wire but I can check.
Old Sep 17, 2010 | 09:59 PM
Bubba 95SN's Avatar
Bubba 95SN
Dark green with yellow tracer wire is on negative side of coil. This will give tach signal..
Old Sep 17, 2010 | 10:10 PM
87Stallion's Avatar
87Stallion
When I switched to carb my stock tach never worked again even after hooking up the dg/y wire to the neg side of coil.
Old Sep 19, 2010 | 10:49 AM
68CSTANG's Avatar
68CSTANG
For some reason my tach wire was tan. I tried hooking up the DG/Y wire and it wouldn't work either. Traced it back and found that for some reason mine wasn't the same color as most.
Old Sep 19, 2010 | 07:52 PM
tohoopty's Avatar
tohoopty
well here in a few days i will have it all hooked up and ill let you know what color i had to use
Old Sep 19, 2010 | 08:06 PM
Bubba 95SN's Avatar
Bubba 95SN
Whatever wire is on the negative side of ignition coil will be the wire for tachometer.
Old Sep 19, 2010 | 08:32 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
my 92 is carb and runs the oem tac , with no issue, can't remember the wire I used but iirc it was out under the hood
Old Sep 24, 2010 | 05:17 PM
tohoopty's Avatar
tohoopty
dark green with a yellow tracer wire is the one that worked for me..thanks for the help
Sminemann
Sep 17, 2015 09:24 AM
Daddys Girls GTs
Sep 14, 2015 08:46 PM
jaiidutch
Sep 14, 2015 10:29 AM
tramphardrocker
Sep 13, 2015 08:56 PM
96stang3.8
Sep 10, 2015 06:42 AM
