Speedo Gear??
The reason I asked is because I didnt know your car was a 5 speed.
AAANYway..... Assuming your T5 is a 93 model, your will have a 8T drive gear on the output shaft, The maximum gear you can correct for without ripping the trans apart (which isnt hard) is 3.55's. That would require you to use the Jeep 23T white speedo gear.
Now if you want your speedo to be correct, you will need to remove the tailshaft housing and swap the gear to either a 6t or 7t gear.
a 6T(black) drive gear will require a 18T(yellow) speed sensor gear
a 7T(yellow) drive gear will require a 21T(red) speed sensor gear
It may work on paper. It may (actually it does) work in reality but after about 20,000km. The driven gear will be chewed up.
Plastic floating around in your transmission is not good.
have fun racking up the mileage on your car faster than you need to.
KingRando
10-02-2015 08:06 AM
junior04
09-28-2015 10:53 AM
