Ford racing spark plug wires and standard fittings
Does anyone have tried putting aftermarket Ford racing spark plug wires on the car, and do they fit in the standard wire holders? Should I worry about them, or I can just leave them hanging without ill effects?
Place zip tie around each wire then put zip tie between each wire. Keeps them seperated and doesn't look too bad. No, the wires are too large for stock seperators. I got my wires done as stated.
Reason: Forgot something
Did you attached them anywhere else, like manifold or head, or just left them hanging grouped by 4? Stock fittings are on the head if I'm not mistaken?
if you tie them together, keep 1 and 3 as far away from each other as possible. Also do this to 5 and 6. This can save you lots of trouble. I was told this and did it to my car. After going to the track and seeing others do it, I wouldn't do it no other way.
