Thermostat?
Old Dec 13, 2010 | 08:01 AM
1987notchback's Avatar
1987notchback
Default Thermostat?
what thermostat should i be running? i was lookin on summit and was thinking 180 but probably to cool. what do you guys recomend and run? thanks mike
Old Dec 13, 2010 | 08:26 AM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
180 is just right for performance!!
Old Dec 13, 2010 | 10:31 AM
AdderMk2's Avatar
AdderMk2
Banned
180 is fine
Old Dec 13, 2010 | 04:15 PM
1987notchback
good stuff thanks guys
Old Dec 13, 2010 | 04:26 PM
TexasTanker19kilo20's Avatar
TexasTanker19kilo20
Goldilocks
When I got my LX it had a 160, but after reading the forums they said it makes it run to cold to which the car would run rich to try and warm up. So I threw a 180 in and have had better results. I agree with previous reply's, go with the 180.
Old Dec 13, 2010 | 05:45 PM
nitrous_bob's Avatar
nitrous_bob
yup 180*
160* if you have no computer tho
Old Dec 15, 2010 | 02:46 PM
4rdnut's Avatar
4rdnut
I believe you have twin electric fans according to your 200 amp alternator thread. Since you can adjust the temperature via the electric fans and when the fans turn on, a 180 degree will work just fine. I have a 180 thermo and when i tested it in boiling water with a meat thermometer it didnt fully open until 188 degrees. Therefore i set my electric fans to turn on at 198 degrees to keep at least a 10 degree gap between fan turn on and complete thermostat opening so i am not cycling the brass thermo open and closed all the time, you want a ten degree gap in between. If you set your electric fan turn on at less than 198 degrees then go with a 160 degree thermo to keep a ten degree gap. A 160 thermo fully opens at 168 degrees.
Nick Oliver
Oct 17, 2018 04:22 AM
Stone629
The Racers Bench
66
Jun 2, 2016 09:52 PM
MusicCity615
Sep 12, 2015 07:05 AM
mrmrultimate
Texas Regional Chapter
Sep 10, 2015 09:43 AM
Wesley1995
Aug 30, 2015 02:01 PM
