Metal coolant lines
Metal coolant lines
I bought this 91 gt and I'm running into all sorts of problems, this is my first 5.0 BTW. The two metal coolant lines that go to the heater core, someone crimped where the coolant sensor went. I'm guessing that this is the sensor that is not for the gauge and the one that is for timing.
Where do the ECT sensor wires originate from so I can try and track these down. Also, depending what I find, where could I buy a new set of lines? The one that had the sensor is leaking from the bottom, not the top where you would think it would be leaking, so it needs to be replaced.
Or if those are too expensive to just buy replacements, what has anyone used successfully in place and where did you relocate the sensor to?
Thanks for the help!
KingRando
10-02-2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
