window trim issues
Old Sep 5, 2011 | 08:52 PM
jets's Avatar
jets
Default window trim issues
Hey everybody,my first night on this forum and am lookimng forward to talking it up on the stangs..I have a question.I had just pulled my 90gt out of storage this past weekend,and noticed the window trim looks like its disintegrating and falling apart.Its pock marked and the texture is nothing like it was when i put it away..Is this sandable? replaceable? Thanks for reading and i look forward to the help.!!
jets
Old Sep 13, 2011 | 08:47 PM
nitrous_bob's Avatar
nitrous_bob
unfortunately those windows are an arm and a leg to replace. glass and trim are 1 piece. if you find new old stock... they are about $700 per window typically
50resto has replacements much cheaper...but no "mustang" on the glass
they can however be repaired... you need 3m "trim black" and 3m "flexible primer"
with something like 1000 grit....wet sand forever...prime, wet sand, prime (repeat about 100x)
once they look good switch to about 1500 for the last coat or 2, then paint the trim black. remove them from the car first....which can be difficult in itself, the butyl tape makes them hard to get out. dont pry hard or you'll shatter them. USE NEW BUTYL TAPE WHEN U reinstall... or they WILL leak fo sho
good luck
LIONS
Jb145700
Aug 21, 2022 06:37 AM
DreadPirateRoberts
Sep 26, 2015 02:11 PM
LivingInThePast
Sep 16, 2015 12:20 PM
Pyrate Dave
Sep 10, 2015 07:30 PM
mdj89
Sep 8, 2015 10:40 PM
