5 Speed Problems
Old Oct 4, 2011 | 11:55 PM
blindboyth's Avatar
blindboyth
Default 5 Speed Problems
I got a 95 GT and Im having issues with the trans. If i try to upshift into second it will pop back out and make a slight grinding noise. If i rev it over 3k in first and granny shift it will go into second. If I downshift into second it will go in as long as I hold the shifter back when I let the clutch out. It does not like to shift into third if im shifting fast at high rpms. Also the clutch does not engage until its at the end of the pedal. It is stock cable, quadrant, and all that. I do not know what clutch but it feels pretty stiff. Like the king cobra in my 89 LX. I Would love it if someone could help me out. Im thinking syncros or maybe bent shift fork.
Thanks in advance,
Trevor
Old Oct 5, 2011 | 02:20 PM
Bubba 95SN's Avatar
Bubba 95SN
Aftermarket shifter? Check adjustment. Transmission, can be shift forks, clutch sleeve, blocking rings, and or gear.Take it apart for a look see.
Old Oct 6, 2011 | 12:16 AM
blindboyth's Avatar
blindboyth
I ended up putting the stock shifter back on. I adjusted the stops on the bbk shifter but it still did no good. could this possibly be fixed by adjusting the clutch?
Old Oct 6, 2011 | 12:33 AM
Canary94GT's Avatar
Canary94GT
If you replaced the clutch, i believe it requires an aftermarket clutch adjustment cable.
Not sure if this applies or is your issue though
Old Oct 6, 2011 | 07:37 PM
Bubba 95SN's Avatar
Bubba 95SN
Remove trans and take it apart, replace along with clutch components.
Old Oct 6, 2011 | 10:53 PM
sn95_331_GT_ yellow's Avatar
sn95_331_GT_ yellow
yep, problem isnt on the outside of the trans, its internal, time for a rebuild
Old Oct 7, 2011 | 12:14 AM
TrimDrip's Avatar
TrimDrip
FudgeDrip
if the clutch is really stiff, you are going to need a clutch quadrent too.
articman
Jun 21, 2018 11:45 PM
SSRFUZZY
Members Other Vehicles
Jan 6, 2016 08:22 PM
musnicki
Sep 23, 2015 07:11 AM
