Which junkyard T5 do I want?
Old 10-16-2011, 04:52 AM
DartorDemon
DartorDemon's Avatar
Default Which junkyard T5 do I want?
I'm doing a T5 conversion on my plymouth duster and i was wonder what's the best year of mustang to pull from for strength? I know the 93' cobra has the best T5, but that's not gonna be common.
Were all the GT's equipped with WC t5's or is it a bit of a crapshoot for finding one?
DartorDemon is offline
Old 10-16-2011, 07:46 AM
projectresto83
M.A.D. Motorsports
projectresto83's Avatar
Assuming your going to have a nice motor powering it....do NOT put a T5 behind it. Stock they are only good for 300-325lbs of torque.
Get yourself a Tremec 3550, TKO600, or a T56.
projectresto83 is offline
Old 10-16-2011, 09:13 AM
AdderMk2
Banned
AdderMk2's Avatar
I too would suggest NOT running a T5 in your car. Although, its not my money, so IDGAF.
Depending on what your car needs for total transmission length, you could go with a fox T5 or an SN-95 T5. The SN-95 T5 is a bit stronger than the fox trans, but it also has the disadvantage of being 11/16" longer than the fox unit. My main suggestion to you is to see how much room you have, figure out the dimensions you can work with, and go from there. You might run into driveshaft issues that you wont see until its too late So what will you do then?
AdderMk2 is offline
Old 10-16-2011, 01:27 PM
DartorDemon
Well luckily, i'm far from the first person to do a T5 swap on one of these cars. So there isnt a driveshaft issue.
The engine that's going in it should be pushing in the neighborhood of 300rwhp/300rwtq.(guessing from a similar build) This is in a car that will be in the weight range of 3000lb-3200lbs without driver.
Sure a TKO is the best transmission to use if you have room for it. Unfortunately, a tko in my car requires a decent amount of fabrication to the tunnel and of course costs a lot more. While a T5 fits a lot easier
Old 10-16-2011, 01:30 PM
DartorDemon
oh and one more thing, the T56 is out of the question, it works for the larger mopars, but on my car you basically have to cut out the entire transmission tunnel and rebuild it to fit the T56 from scratch.
Old 10-16-2011, 05:13 PM
nitrous_bob
nitrous_bob's Avatar
all v8 cars from '85+ were world class. here is a link to the tag that is on the case...there will be a 1352 then 3 more digits. the 3 digits after are the important ones. and it HAS to be the tag...not anything else. every part on a t5 has a prefix of 1352
newer than '90 is best, if you dont wanna break it down, to replace the drive gear stay with a 7t trans
on a 8t trans you CANNOT correct for 4.10 and above
http://www.ddperformance.com/techinfo.php
heres a really braod 3 digit breakdown......d&d is better but my adobe is not responding
http://www.britishv8.org/Articles/Bo...T5-ID-Tags.htm
nitrous_bob is offline
ThatJuanStang
09-25-2015 08:01 AM
67LimeCoupe
09-21-2015 06:34 PM
vipergtrdj
08-25-2005 10:41 AM
mkspeed26
North East
04-17-2005 11:32 PM
Epd711
North East
01-25-2005 11:32 PM
Quick Reply: Which junkyard T5 do I want?
