mexican block
Old 01-30-2012, 10:25 AM
Tony71502
Tony71502's Avatar
I thought I read somewhere the mexican blocks had a higher nickel content making them slightly stronger? Maybe mistaken.
Tony71502 is offline
Old 01-30-2012, 05:58 PM
TrimDrip
FudgeDrip
TrimDrip's Avatar
all early 302 and 351s had a higher nickel content up until like 74 or 5.
350 and a standard bore, I would buy it. If it was already 30 over I would look elsewhere.
TrimDrip is offline
Old 01-30-2012, 07:10 PM
Bobert
Bobert's Avatar
didnt know a mexican was that strong, hmm, i may have to look into finding one of these haha. in canada. . .
Bobert is offline
Old 01-30-2012, 11:34 PM
tinman
tinman's Avatar
The Mexican block might be worth having if you were using a mechanical roller cam.
Otherwise I'd say no to it.........
tinman is offline
Old 01-31-2012, 05:10 PM
Bobert
Bobert's Avatar
Can you expand? Are you only refering to the cost of the special rollers?
Or is there another reason to pass on a mexican block
Bobert is offline
Old 01-31-2012, 10:37 PM
jojobanks
jojobanks's Avatar
the strength difference of earlier blocks won't really carry you that far. If you're building a high hp block you'll want to go aftermarket anyway.
it'll cost you $500 at least for retro-fit hydraulic roller lifters. Just for that fact alone i wouldn't get it.
all that said there should be no difference between a block made in mexico and a block made in the usa. If you bought the same size/year block made in the usa it would be the same block.
jojobanks is offline
Old 02-01-2012, 12:11 AM
Bobert
Bobert's Avatar
http://www.oldwestracing.com/index.h...es/mexican.htm
Bobert is offline
GimpyHSHS
19
12-19-2023 01:12 PM
mustangheaven
01-03-2016 11:20 AM
Matt's 95 Stang
10-05-2015 07:16 AM
mustangheaven
09-29-2015 11:00 AM
wraith777
09-28-2015 10:49 AM
Quick Reply: mexican block
