A/C Help
1992 Mustang 5.0-System was R12, so I'm converting to 134. I vacuumed the systems and filled with 134. The compressor will cycle for a second or two, so I'm assuming maybe its good? It's only blowing hot air in the car and my friend helping says the 134 is not flowing through the systems. Before I just started throwing money at it, I thought maybe I would check with the experts and get some insight. Any thoughts on where I should start? Accumulator, Orifice Tube, or any thing I could check on the car? TIA
Converting from R12 to R134 is not that easy.
Besides the obvious high/low side valve size differences,
- You need a new compressor (R134 runs at a higher pressure than R12 and the seals are not cross compatible) SO, even if it works for a bit, it will blow out the seals on the compressor.
- ALL of the o-rings need in the system need to be replaced or you will get a leak.
- You also need to replace the receiver drier and flush (not just vacuum) the AC System. R12 uses mineral oil for lubricant. R134 uses PAG (a synthetic oil) for lubricant. They are not compatible with each other and R134 will not carry the oil to where it's needed so you will end up burning up your compressor even if it does fire up and that's if a leak doesn't happen first from the wrong o-rings or wrong oil.
Start over.
Start over.
Start over.
Start over.
You DO NOT NEED A NEW COMPRESSOR, nor receiver dryer to convert to 134a in a foxbody………if all r-12 is out.....put on the 134a conversion fittings, if you need to add oil if any components were changed add ESTER oil then pull system into a vaccum and leak test then charge to 80% of the r-12 charge using 134a...……..I have converted multiple foxes to 134a and never an issue using the above method...…….you could change seals but I rarely do as ester oil is compatible with 134a and r-12 oil......if your a/c is not working right after the conversion, you need to have a set of manifold gauges hooked up and see what the pressures are on the low and high side.
Ester oil is synthetic like PAG and can be used if you're not draining out the old R-12 oil. Thank you for pointing that out.
Regardless, the problem now is, where did he go wrong? It could be the install, it could be the refill method, it could be a simple unrelated low pressure switch which would not be his fault. I've always been one to start from scratch on conversions and such so I can rule out certain bits of uncertainty.
OP, your helper is correct that the refrigerant is not flowing through the system. That's what the compressor does (pushes the refrigerant through the system).
What do the manifold gauges say when you fire up the A/C? If they don't change much or at all, it could be insufficient R-134A in the system or a defective low/-pressure switch. It's typically located on the Receiver drier. If the A/C kicks on, when you shut off the car, your high/low sides should equilibrate fairly quickly <1 minute during warmer temps. If the pressures don't equiplibrate or the process is really slow, a clogged orifice tube is possible.
WBROCKSTAR,MJR46,DERF00-Thanks for your replies. The help/comments are appreciated. My 89 GT went smooth years ago when I converted the AC. Just added the 134 with no problems, but this 92 LX did not. I do have another pressure switch, so I can check the switch and make sure its functioning properly. It may be the weekend before I can check when the pressure gauges. Any steps/advice on moving forward ? What should I read on the gauges and if it reads this check that? If I remember when we were filling with 134 it read high pressure on the low side.
MustangMan1718
Apr 26, 2016 04:31 AM
