Sponsored by:
Sponsored by:
Help A/C problems
Old Aug 4, 2018 | 01:35 PM
Jarrod Walker's Avatar
Jarrod Walker
Default Help A/C problems
My driver side will blow hot air but no cold air. The Passenger side will blow both. I took off the actuator on the driver side and manually controlled it. The heat worked the same and the cold still blew outside temp air. The clutch cycles on and the A/C lane gets cold and condensates. I had it taken to Ford about 3 months ago when this happened before. They checked for leaks and found none. Said everything was good and refilled coolant. Does anybody know what the problem might be?
Old Aug 4, 2018 | 02:55 PM
sfs550's Avatar
sfs550
Change your service dealer and keep all receipts..Hope yu are still under warrenty. Since they had to refill coolant, there
must be a leak. Have them install a dye to trace the leak. They shud find a leak at the vent in the dashboard. This may be a
A/C evaporator Assm replacement job.. This is a very expensive repair, parts and labor close to $3000.00 as the dash has to
be removed to get to the evaporator. Like I said, hope yu are still under warrenty.
Old Aug 4, 2018 | 04:34 PM
don-ohio's Avatar
don-ohio
You have a 2015 GT? Not under warranty as said above? If the car has a DCCV valve, one side may be mixing hot air into the driver's side. Just guessing and hope it's still under warranty.
Vinny.
Mar 9, 2017 04:59 PM
sandawilliams
Apr 16, 2015 05:24 PM
micahb
Aug 7, 2012 08:34 PM
bplemmons
Nov 1, 2008 08:02 PM
Dancj2
Jul 15, 2006 12:15 AM
