5.0L V8 Technical Discussions Any questions about the 'Coyote' engine, transmission, exhaust, tuners/CAI, or gearing can be asked here!
Using a floor Jack?
Old 09-24-2011, 04:29 PM
REDBOSS1
REDBOSS1's Avatar
Default Using a floor Jack?
Have any of you used a floor jack to jack up your car? If so where are you placing it? I'm looking underneath the car with a flash light and I can't tell what is plastic and what is not.....and no I can't reach the middle parts underneath the car. This is in the front of the car, to change oil ect...
REDBOSS1 is offline
Old 09-24-2011, 04:52 PM
JIM5.0
JIM5.0's Avatar
I use a floor jack all the time. For jacking the car up, I use the load bearing points, where the plastic rocker panel on the underside has square tabs cut out and you can feel the thin metal "slats" or strips.
I do not put the jack stands on those, I pit them on something more solid. On the front end, when I change my oil, I put them on the diagnol chassis brace bars just in front of the cats. See this link for a pic, these diagnol braces are painted black.
http://wot.motortrend.com/2010-new-y...l/image-18341/
JIM5.0 is offline
Old 09-24-2011, 05:01 PM
REDBOSS1
REDBOSS1's Avatar
Thanks for the image, you talking about the spot right in front of the oil pan?
REDBOSS1 is offline
Old 09-24-2011, 05:06 PM
JIM5.0
JIM5.0's Avatar
Actually, further out to the sides.
On these diagnol braces, there are "oval" or pill shaped cut-outs. These cut-outs are almost just in front of the cats and just behind the suspension A-arms.
The transverse brace that goes under the MT82 and conncects to the diagnol braces is whee these cut-outs line up.
JIM5.0 is offline
Old 09-24-2011, 05:16 PM
REDBOSS1
REDBOSS1's Avatar
Gotcha, thanks.
REDBOSS1 is offline
mtgldr
02-03-2024 09:00 PM
baddog671
07-26-2016 01:20 PM
b8checker
10-08-2015 12:55 PM
b8checker
09-30-2015 07:11 AM
ThatJuanStang
09-25-2015 08:01 AM
Quick Reply: Using a floor Jack?
