Question about J&M camber plates?
Looking at the provided pictures it seems that the bottom portion of the plates move side to side in relation to the top portion. I imagine the guy doing the alignment would line them up to where they need to be and then tighten down the hardware.
So I'm curious. After the alignment is complete, can you remove the plate nuts without affecting the alignment? I have a strut tower brace that I'd rather install myself, but don't want to make a stupid mistake that will cost me another alignment visit.
Thanks!
http://www.americanmuscle.com/2005-c...er-plates.html
http://www.americanmuscle.com/black-...race-2005.html
Thanks!
Thanks!
Thanks!
You shouldn't have a problem with this set up at all. You can either throw the brace on first then take it to get aligned or you could get the CC plates and alignment done first then throw the brace on. Considering your only taking the nuts off and your not actually removing the plates, you won't throw anything off.
I hope this helps, Let me know if I can be of any assistance!
-Dan
Maybe I will install it prior to having the alignment and just leave it alone.
maestro1024
Sep 21, 2015 02:40 PM
ccdguy
Sep 19, 2015 05:20 PM
