Audio Questions???
Old Apr 29, 2006 | 05:43 PM
97GTstaz's Avatar
97GTstaz
Default Audio Questions???
I want to make a portable stereo out of a head unit and two car speakers (6.5 or 6x9). Can I run them off of a motorcycle battery and how long would this setup last before needed to be recharged? The system will probably run around 200watts total.
Old Apr 29, 2006 | 06:20 PM
bonesninja's Avatar
bonesninja
Default RE: Audio Questions???
ORIGINAL: 97GTstaz
you need 12 volt power source for the headunit.........i think motorcycle batts are 6 volt?
Old Apr 29, 2006 | 06:27 PM
1fastzook's Avatar
1fastzook
ORIGINAL: bonesninja
ORIGINAL: 97GTstaz
a motorcycle batt is 12 volts but i dont think that it would last long.look in to a odyssey batt they have some small car batts that should do the job.batterymart.com
Old Apr 29, 2006 | 06:31 PM
1fastzook's Avatar
1fastzook
Or i guess you could put 2 or more motorcycle batts together or maybe a lawn mower batt.
Old Apr 29, 2006 | 06:41 PM
97GTstaz's Avatar
97GTstaz
I want the whole thing to fit inside of a cooler. Thats why I was looking at the motorcycle battery that I have. I just checked it and it is a 6v. Thanks for the battery mart link.
Old Apr 29, 2006 | 06:45 PM
1fastzook's Avatar
1fastzook
i have a yamaha raptor 4 wheeler and it has a small 12 volt batt you might want to look for one or two of those batts too.
Old Apr 30, 2006 | 04:16 AM
Melectrok's Avatar
Melectrok
how are you getting 200watts? You hooking an amp up also?
Old Apr 30, 2006 | 06:36 PM
97GTstaz's Avatar
97GTstaz
Sorry I forgot to mention an amp also. I really want to know how long the system would last without charging the battery. I dont want to have to buy car battery and a motorcycle battery and run them both to compare.
Old Apr 30, 2006 | 07:04 PM
Melectrok's Avatar
Melectrok
Dont use an amp then, just run off deck power
Old May 1, 2006 | 12:07 AM
Sean97's Avatar
Sean97
A deck would be plenty of power for a couple 6x9s.
What about those honda gel cell batterys? They are smaller than a 6 pack, I think.
