2 10's setup question
Old May 25, 2006 | 11:42 PM
ibeeskeef's Avatar
ibeeskeef
Default 2 10's setup question
Has anyone removed their back seats and put subs in their place? I have a vert so I can't just fold the back seats down like you hard top people do. I am actually going to remove the back seats with a rear seat delete and put a 10 in the spot where each seat used to be facing straight up and have the amp sitting in the middle of the two subs. Has anyone ever done this? Is there enough room to box off for the subs to get a descent sound in this area? Any advice I can get would be awesome and if I could get pics that would be even better.
Old May 26, 2006 | 03:11 AM
grasshopper's Avatar
grasshopper
Default RE: 2 10's setup question
I think in that scenario you'd be better off with a downfiring or slot-loaded enclosure. You'd basically build the same box, but turn it over and elevate it so there's about a 2" gap underneath. Then you can pile stuff on top, the subs are protected and it will reduce any audible distortions from the woofer cones. Should be plenty of area for 2 10s. Expect the enclosure to stick up a good 8-10" though.
jwog666
Dec 27, 2021 08:09 PM
Lethaldosage423
Oct 19, 2015 12:12 AM
treesloth
Sep 28, 2015 07:03 AM
