Melted the Remote Wire!?
Old Jun 6, 2006 | 07:47 PM
checkuself1222's Avatar
checkuself1222
Default Melted the Remote Wire!?
Well today my radio wasn't working so I was checking out all of the wires to see what was up. I noticed that one of the wires into the amp came loose so i tightened her all up assuming it would fix the problem, so I put the key in and try to turn on the radio when i start seeing smoke come pouring out so I immediately shut off the car and start to check out what was up. Turns out that my remote wire is fried, the whole thing is shot, all the insulation around it like burnt up. I started following the wire back and found that the 8 gauge power wire had a slice in it from rubbing and the remote wire was touching it. My guess is that the power went through the remote and since it was too small of gauge shorted it out or something, i'm not sure. Now the radio wont go on and the windows won't go up. Does anybody have any clue what happened here because I sure dont. I have an 850w planet audio amp with 2 JL 10 w6's off the stock headunit btw.
Old Jun 6, 2006 | 07:56 PM
1fastzook's Avatar
1fastzook
Default RE: Melted the Remote Wire!?
Check your fuses
Old Jun 7, 2006 | 02:49 PM
Melectrok's Avatar
Melectrok
Did the power wire melt from the amp to the where it shorted with the power wire, or from the short to the radio.
Old Jun 7, 2006 | 06:28 PM
checkuself1222
The remote wire melted from the short to i'm not really sure where to actually it looks like it goes to the ignition, but the power wire only melted where the remote wire was touching it just because the remote got so hot.
jwog666
Dec 27, 2021 08:09 PM
Urambo Tauro
Oct 5, 2015 09:37 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
Dathan
Oct 5, 2015 05:52 AM
lmurf60
Sep 24, 2015 10:07 PM
