Lanzar Amps and Mach 460 question
Old Jun 26, 2006 | 01:42 AM
wilburgtwoot's Avatar
wilburgtwoot
Default Lanzar Amps and Mach 460 question
I recently was running a Lightning Audio 450 watt amp in my mach 460 on a red Sony Xplod 10' inch 1100 watt subwoofer. The amp was over heating and shutting off after a while, so I decided to upgrade to a better amp. I went with the Lanzar Vibe426 1600watt 4 channel amplifier. Whats happening is this...the amp will be hitting hard one second, but in a few moments it will start hitting soft for some reasons. It goes back and forth between hitting soft and hard, and I'm not sure what the problem is. I want to upgrade to a second sony xplod 10' and run two, but I'm worried that the amp will keep doing whats it doing. I'm not sure if it might be an overheating problem, I did feel the amp a while back and it did feel a bit warm around the edges, but I really don't know anything else I can do to keep it cool. The box and amp are in the trunk of my 1999 mustang GT. The amp shouldnt be overheating just pushing some xplods. I thought it might also be that I might not have a good enough ground for the amp, but in my mustang I had some trouble finding a good ground screw, and the one I found looks like it was coated over just a tad when it was painted. That might very well be the problem, but I don't have another ground that I know of, and I don't know how to make a custom ground in a car. Let me know what you guys think, hopefully you know something about lanzar amps, and maybe we can get this problem squared away.
Old Jun 26, 2006 | 05:02 PM
ttocs's Avatar
ttocs
Default RE: Lanzar Amps and Mach 460 question
how many ohms is the rating on the sub and how do you have the 4-channel amp wired to the sub?
Old Jun 27, 2006 | 07:59 PM
wilburgtwoot
ORIGINAL: ttocs
The subs are rated for 4 ohms. The layout of the amp has 2 channels on the left side (+ - + -) and 2 channels on the right side (+ - + -). I had the one subwoofer connected on the first set of channels on the first positive input and on the last negative channel input. I went to a audio shop and he told me that I couldn't do this, that I needed to run the one sub on the first set of positve negative inputs, channel 1 on the amp. The sub isn't bridged anymore, and it's not overheating, but I still don't want to run it on one channel. I now have the second 10' xplod and I am wanting to connect them both to the amp. Do you have any idea how I should connect the subs to the amp without causing it to overheat?
Old Jun 28, 2006 | 03:55 AM
ttocs's Avatar
ttocs
one more question, four ohm single voice coil?
Old Jun 28, 2006 | 09:08 PM
marcus30's Avatar
marcus30
don't think it's your ground i've made my own ground drilled a hole throw part of the frame sanded it then made sure it was tight. i'm running two sony 12" xplod's a 1200 watt xlpod amp and a 250 xplod amp for the mid's and high's
Old Jun 29, 2006 | 07:02 PM
wilburgtwoot
I need a little help setting up the crossover again, can someone explain which wires to splice into and where to run them again? I accidently pulled a few wires off when i put in my new box and I absolutely forgot how I set them up before. Also, I need to know how to connect the 2 sony xplods to the lanzar Amp. The amp has 4 channels, rated at 4 ohms, the same as the subs.
Old Jun 29, 2006 | 08:30 PM
1fastzook's Avatar
1fastzook
ORIGINAL: wilburgtwoot
not sure what wires you pulled out?set your crossover to 80-100 hz.i would bridge it but you said it overheats.The overheating can be caused by low voltage or too small power wire.
Stone629
The Racers Bench
66
Jun 2, 2016 09:52 PM
PaulH2
20
Jan 31, 2016 09:48 AM
treesloth
Sep 28, 2015 07:03 AM
1BAD3V
Indiana Regional Section
Sep 26, 2015 09:03 AM
iamgobono
Sep 3, 2015 12:37 PM
