lights dimming
Old Jul 21, 2006 | 03:30 PM
stangcrazy's Avatar
stangcrazy
Default RE: lights dimming
ORIGINAL: Derf00
ORIGINAL: stangcrazy
IMO a system that size shouldn't require a Cap.
In a newer car it wouldn't. But in a classic the wiring/charging system was not designed for a whole lot so that amp punches the charging system in the gut every time it hits.
Ahhh well you got my vote.
Old Jul 21, 2006 | 04:00 PM
dandragonrage's Avatar
dandragonrage
Upgrade your big 3 (alt to battery, engine to battery ground, battery to chassis ground, and you can add an engine to chassis ground as well if you want). Make sure your ground for the amp is in a good location.
I don't recommend a capacitor unless your lights only dim a tiny bit. Capacitors put more of a strain on your electrical system, but they will help smooth out the load a little bit.
If the upgraded wiring doesn't help, an upgraded alternator is best. Don't bother upgrading your battery unless you plan on running the system w/o the car running. In which case an Optima yellow top would be good.
Old Jul 24, 2006 | 02:05 AM
1998gtcorpus's Avatar
1998gtcorpus
k guys start by checking your ground...when an amp has a bad ground it tends to draw alot of current hints lights dimming...k then make sure its the proper size power and ground wire for your setup
Old Jul 24, 2006 | 02:30 AM
backinblack06's Avatar
backinblack06
ORIGINAL: 1998gtcorpus
Or the amp Is just drawing to much power for the alternator like everyone else said.....Alternator or a Max Cap will def do the trick or ya !
Old Jul 24, 2006 | 02:35 AM
1998gtcorpus
yes i know that but bad grounds can cause an over consumption of current due to lack of ground path
Old Aug 3, 2006 | 09:20 PM
pure7poison's Avatar
pure7poison
it probably has to do with your battery...so most likely you would need a capacitor since your battery isnt strong enuogh
jwog666
Dec 27, 2021 08:09 PM
4cylinderplus2
Oct 9, 2020 07:45 PM
lincolnshibuya
Dec 8, 2015 04:37 PM
Explosive
Oct 2, 2015 07:45 AM
folivier
Oct 2, 2015 05:34 AM
