remote start help
Old Oct 25, 2006 | 09:26 PM
86stanggt5.0's Avatar
86stanggt5.0
Default remote start help
i am installing a remote start and car alarm on a 86 mustan gt. my car does not have power door locks is it still possible to install this? and if so what can i do with the wires? also when i try the code learning mode on off 3x my siren just beeps constant not two beeps like it should Please HELP thank you
Old Oct 26, 2006 | 04:17 AM
ttocs's Avatar
ttocs
Default RE: remote start help
gonna need to know brands and model numbers if we have any chance of helping with software.
You can still install it and not hook up the door locks, or install actuators to move the lock rods up and down. How much experience do ya have with auto security installation?
Old Oct 26, 2006 | 05:46 PM
86stanggt5.0
http://alarmsellout.com/support/f-81...ng-diagram.pdf
magicar fai 8100
ok i hooked it up like u said but still nothing
this is how i did it
c1-1 red black to on red light green ignition to orange 86 on relay c1-2 yellow/green to start white/pink starterto red number 30 on relay cut the white/pink wire and ran 87a to that c1-3 blue/white acc to black/light green acc c1-4 red to constant 12v c3-1 to ground c3-2 white indicator light did not use this wire c3-3 gray ignition 2 to relay 85 c3-4 to positive side of siren c3-5 black/red to ground c3-6 yellow to start disable relay 85 c3-7 red/white trunk motor did not use c3-8 violet to to 12v constant c3-9 to door trigger c3-0 to hood trigger c4-1 to tach which is dark green/yellow on the coil do i have this right
here is my ignition wire colors
starter white/pink
ignition red/light green
accessory black/light green
i pulled the whole thing out and started all over and still nothing
suppose to chirp twice when i turn ignition on off 3x and push button 1 on remote within 10 secs should chirp twice to confirm that it learned the code but nothing happens it just does a long sound when i turn ignition on/off 3x
zsmart
Convertible Tech
Feb 29, 2016 08:33 AM
1TUFF302
Nov 5, 2015 04:02 PM
StalkerGT
Sep 25, 2015 02:41 PM
dalefrancis88
Sep 11, 2015 07:15 AM
5.0 kevo
Sep 3, 2015 06:24 PM
