Mach 460 fuse
Old Dec 15, 2006 | 12:04 AM
2000slvrGT's Avatar
2000slvrGT
Default Mach 460 fuse
I have a 2000 gt with a mach 460 sound system and there is no sound coming from my front door speakers or my tweeters. I hooked up the amp the powers the speakers to the other side and found out that the amp was working fine so my next guess is that the fuse for the driver side amp is blown. I purchased the car used and never got an owners manual so i was wondering if anyone could tell me which fuse powers this amp and whether it is located under the dash with the other fuses or not.
Old Dec 15, 2006 | 03:15 AM
Jazzer The Cat's Avatar
Jazzer The Cat
Retired Moderator
Default RE: Mach 460 fuse
I there is only one fuse for both amps located under dash. I just pulled mine out yesterday as I am building a new system and removed all the old components. It is a 30 amp fuse and location #9 if memory serves.
Jazzer
Old Dec 16, 2006 | 02:37 PM
2000slvrGT's Avatar
2000slvrGT
I checked the fuse and it was fine... any other ideas of why my front speakers being powered from my driver side amp are not having any sound coming from them but my subs powered by the other amp are working fine?
Old Dec 16, 2006 | 08:10 PM
ttocs's Avatar
ttocs
when I go to check fuses, I check ALL the fuses. This included the fuses under the hood by the batt. It only takes alittle longer, but sometimes circuits are tapped off of other circuits that you would not exect.
Old Jan 7, 2021 | 12:19 PM
Gulfbreeze's Avatar
Gulfbreeze
Default Mach 460 amps
The fuses are located under the dash and there are also fuses under the hood. The amps do not have any fuses in them. Amps usually get blown because of after market installs.
scseg
Aug 11, 2009 10:40 PM
four-sixer
May 22, 2007 09:38 PM
four-sixer
May 22, 2007 12:02 AM
JJ_Stang
Dec 1, 2005 02:44 PM
01roushnj
Aug 31, 2005 07:36 PM
