2-4 ohms
Old Dec 25, 2006 | 06:51 PM
Volcom66's Avatar
Volcom66
Default 2-4 ohms
so i have one JL 12W3V2-D4 and i want to get an amp but im not to good with this type of stuff. i know ohms are a measure of resistance so when my sub says 4 ohms and 500w peak. should i look for a amp with 500w at 4ohams or with 500w at 2ohms... im so lost
Old Dec 25, 2006 | 07:22 PM
ttocs's Avatar
ttocs
Default RE: 2-4 ohms
you will want an amp that will give you maximum output at 4 ohms since you have a 4 ohm speaker. If you get an amp that is 2 ohm stable you can use it as well, and also add another sub later if you want with out replacing the amp.
Old Dec 26, 2006 | 08:06 AM
97tunedmustang's Avatar
97tunedmustang
ORIGINAL: ttocs
Your kinda right at first but not really. If he got a 2ohmamp it would work fine for one subbut if you triedto wire the speakers properly in a dual sub setup itd be physicallyimpossible to run 2ohm or 1.Theirfore you'd be stuck with 4ohm as the only viable option the amp would support and youd end up with half the rms output from the original single speaker,If he is smart he'll get a strong 1ohm stable amp like the hifonics brutus bxi606. He can wire the one subwoofer in series and get 300rms out of that amp for the subwoofer which is 300rms also. Then because its 1ohm stable if he gets another just like it he can wire both of them in parallel and run 1ohm stable at 600rms to both which is perfectly matched.
Old Dec 27, 2006 | 02:29 AM
TsmithGT00's Avatar
TsmithGT00
ORIGINAL: 97tunedmustang
ORIGINAL: ttocs
Well said
Old Dec 27, 2006 | 02:25 PM
ttocs's Avatar
ttocs
ORIGINAL: ttocs
Am I missing somethin, he has a single voice coil speaker right? If hegets an amp that can run 2 ohm mono(class d ampsare normally used forsubs), he can run his single speaker currently at 4 ohms. This will of course get less power from the amp then it would if you ran it at 2 ohm mono( most class d amps are made to max out at 2 ohm mono), but he could use this set up until he got another sub, and then just wire it into the same amp.
Old Dec 27, 2006 | 11:20 PM
silver2006's Avatar
silver2006
ttocs you are correct. if an amp is stable at 2 ohms it will be stable at 4ohms just with less output power.
Old Dec 27, 2006 | 11:32 PM
96Firebird's Avatar
96Firebird
Alright, after looking up the sub, you have a 4ohm DVC sub that has RMS rating of 300W. So you want to look for a D-class (mono) amp that puts out 1 x 300WRMS @ 2ohms. Like 97tunedmustang said, the HiFonics BXi-606 would work well with this setup, and also would work if you were to add another sub later on.
Old Dec 28, 2006 | 01:57 PM
ttocs's Avatar
ttocs
I disagree. if he gets that, he will be getting 1/2 half that power of the amp, or 150 watts rms to the sub. Then when he upgrades, he will get 300 watts power out, to 2 subs again leaving him with 150 watts per speaker. It is easier to blow a speaker with toolittle power then it is with too much. Driving the speaker with too little power causes the signal to clip, or basically feed your speaker a DC signal and there is nothing worse then giving a speaker DC voltage.
he needs an amp that is rated at 300 watts at 4 ohms rms, and 600 watts at 2 ohms.
ORIGINAL: 96Firebird
Old Dec 28, 2006 | 06:51 PM
97tunedmustang
ORIGINAL: ttocs
Hifonics Bxi606D[*]1 ohm: 600 watts x 1 RMS[*]2 ohms: 300 watts x 1 RMS[*]4 ohms: 150 watts x 1 RMS
If he has just the one subwoofer he can wire both voice coils in parallel causing a 2ohm load which gives him 300rms from that amp, which is the subwoofers rms rating. If he runs 300rms to one of those voice coils at 4ohmhe'll blow it. each vc individually handles half the subs supported rms, and he would be doubling its handling capacity. not smart
Later down the line ifyou want to get two subwoofers that are both dual 4ohm vcyou can wire them bothin parallel creating a 1ohm load and the amp then will put out 600rms also matching the subwoofers combinedrms rating.
Old Dec 28, 2006 | 11:22 PM
ttocs's Avatar
ttocs
ah shoot, sorry, missed the DVC part.... I will shut up now..........
SteelerNation82
Sep 16, 2015 07:11 AM
skm52670
Mar 27, 2006 05:33 PM
Dark_Horse
Dec 18, 2005 05:40 AM
baddog671
Oct 20, 2005 03:59 PM
Cogtx
Aug 31, 2005 08:39 PM
