stuck & confused
Old Jan 1, 2007 | 05:37 AM
Trigg's Avatar
Trigg
Default stuck & confused
ok so im tryin to redue my whole audio system, iv got my headunit and subs now my problem is amps and door speakers
Head-Unit: http://www.sonicelectronix.com/pictures.php?id=6917[*]Peak Power Output:[/font]50 watts x 4 chan.
[/align][*]RMS Power Output:20 watts x 4 chan.
[/align][*]Preamp/RCA Outputs:3 Pair - Front, Rear, Sub
[/align][*]Preamp Voltage:[/font]2.5 volts
Subs:2 12"EclipseSW8200[*]RMS power handling: 670W[*]Max. power handling: 2000W[*][font=arial]12" Subwoofer[*][font=arial]Single 4 Ohm
Now my problem is what kind of door speakers should i get? Size? Watt?
Id like to get eclipse brand.
I guess the harder of them all what kind/type of amp should i get?Im gonna have 2 12" Eclipse SW8200 subs in the trunk sothats 1350 RMS Watts.I have no clue about what RMS means and what watt is needed for each speaker or what the Ohm's r. completely ignorant on this part. Specifics would be great. Thanks guys
Old Jan 2, 2007 | 12:59 PM
Jazzer The Cat's Avatar
Jazzer The Cat
Retired Moderator
Default RE: stuck & confused
Always a good idea to get the same brand of speakers all the way around (subs can be an exception, usually) You want to "match" the sound out of all the speakers so the X-over points are the same, and (for example) the symbols sound the same all around the car. For example: titanium tweeters tend to sound crispy to me. If you have titaniums in front, and soft domes in rear (you will hear the difference in most cases)
jazzer
Old Jan 2, 2007 | 04:06 PM
ttocs's Avatar
ttocs
you have 5 x 7's all the way around. You can fit a 5 x 7, 6 x 8, or even build a baffle for a 6.5.
mrtrodonet
Sep 19, 2020 03:12 PM
marc954
Sep 29, 2015 03:05 PM
mrappe
Sep 26, 2015 10:16 AM
jstrothe
Sep 24, 2015 12:17 PM
rafotree
Sep 22, 2015 03:55 PM
