How much power through stock Head Unit?
Old Jan 21, 2007 | 07:14 PM
kcp1989's Avatar
kcp1989
Default How much power through stock Head Unit?
I have a 02 gt that is a non mach. It has the single cd. changer. I have purchased all new speakers to replace the crappy stock one. Im doing 6.5" component speakers in the back rated for 350w each. Up in th edoors will go 6x8 speakers rate at 250 watts a piece. Will I have enough power for this setup to sound good or will I be needing a new headunit/amp/wiring for it to sound good.
Also does my car have an external amp?
rms for 6x8 is 250 total
rms for 6" components is 175 total
Old Jan 21, 2007 | 07:32 PM
ZW99GT's Avatar
ZW99GT
Default RE: How much power through stock Head Unit?
I have no clue. Post your question here. You will probably get better response
https://mustangforums.com/forumid_34/tt.htm
Old Jan 21, 2007 | 09:21 PM
kcp1989's Avatar
kcp1989
im planning on just rewiring everything with some heavy speaker cable and getting an adapter harness to splice everything together while bypassing the amp
Old Jan 21, 2007 | 09:56 PM
CrazyDan's Avatar
CrazyDan
im pretty sure u'll need a new amp....i suggest MTX...or Kicker.....oh and dont forget to get a ground wire =)
Old Jan 22, 2007 | 12:19 AM
PReal's Avatar
PReal
Simply put, you will not have enough power to make the components sound good.
Please link both the comp and 6x8's actual info.
DO NOT PUT THE COMPS IN THE BACK, THAT IS A TERRIBLE IDEA!!!!!!! If you need me to explain I will, but I have a descent amount of experience in car audio, and you want your best speakers in the front.
You will need 4 channels worth of line output converters, an amp, and an install kit.
If you provide the actual specs I will recommend you a very nice amp for a good price.
Old Jan 22, 2007 | 02:42 AM
ttocs's Avatar
ttocs
you don't NEED amp but it will sound better with an aftermarket amp, or even with an aftermarket deck with more power. Stock power is prettywell unknown since they inflate those numbers soo much. You might have 10 watts if you are lucky....
Old Jan 22, 2007 | 12:42 PM
kcp1989's Avatar
kcp1989
i found somewhere that the stock hu is around 18 watts and the 6 disc is 22 watts.
Old Jan 22, 2007 | 12:51 PM
PReal's Avatar
PReal
Saying you don't need an amp is like taking 4 spark plugs out of a V8 and saying it will run.
If you don't want to buy an amp, just buy a set of coax's and call it a day. Components will produce less sound at low power becuase the crossover draws a considerable amount of power.
Urambo Tauro
Dec 17, 2016 03:30 PM
Soldier GT
Aug 12, 2015 03:46 PM
pjrolvrz
Aug 10, 2015 02:10 PM
pjrolvrz
Aug 10, 2015 01:39 PM
dragman72
Aug 9, 2015 12:54 AM
