Subwoofer/Amp help needed
Old Jan 26, 2007 | 08:36 PM
IA_Chiefs_fan's Avatar
IA_Chiefs_fan
Default RE: Subwoofer/Amp help needed
ORIGINAL: P Zero
Overdriving is good since most people blow their speakers due to lack of power rather than too much. But overdriving a 200w sub with a 500w amp is totally pointless, unless he is going to be using the 8ohm driver.
Also, this is where THD% comes into play. THD% is how much of the signal will get distorted. THD stands for total harmonic distortion. And even with the sh!ttiest amp it will be no more than 1%, and that would litterally be the WORST amp you can buy. The reason highend amps cost so much is not because they produce a cleaner sound (usually), its because theyre 1 ohm stable and some are even .5 ohm stable. For bridging purposes.
-P.
PS: If youre going to use that 8ohm driver then get the 500 watter. If youre going to be using a 4 ohm driver with a 200w RMS input, 200w RMS output amp shoud suit your needs just fine.
If I want to run both 10s with a mono amp how would I hook up the subs and how many watts should the amp be? Also, nothing other than more watts is needed for an 8ohm sub? Is an 8 ohm sub better or worse than a 4 ohm sub? Thanks for the help guys!
Old Jan 26, 2007 | 10:16 PM
Jazzer The Cat's Avatar
Jazzer The Cat
Retired Moderator
Couple thoughts on lowering cars (been doing that for alot longer than stereos). The stiffer thesuspension, the worse the handling (for cars on the street, course racing is a little different).Without suspension travel, the car cannot absorb the shocks in road (as you have no doubt felt) A great trick to lowering car without messing up the spring rate, is remove thespring pads on top/bottom of springs. That way you lower the car an additional 3/8" to 1" (depending on several variables)so the ride is still good over bumpsand doesn't beat up the kidnies, kidnees, kidny's (how do you spell kidneys?) If you lower the car too far, you ride on the bump stops and you get bad handling AND bad ride. That is what happened to me when the springs came out of position. I was riding on the axle! My '85 GT handled FANTASTIC on very smooth roads, but when I hit a bump, the rear would want to slide out b/c the suspension could not absorb the bump and rear would get light.
As far as looks, you cannotlower a car too far IMO.
The Jazzer on dumping your car to the weeds
Old Jan 27, 2007 | 01:26 PM
PReal's Avatar
PReal
ORIGINAL: IA_Chiefs_fan
ORIGINAL: P Zero
-P.
I CANNOT STRESS ENOUGH THAT YOU SHOULD NOT RUN BOTH SUBS AT THE SAME TIME!!!!!!!!!!
The difference in ohm's is realted to the resistance of the voice coil and has nothing to do with better or worse. The two subs would each require an amp to suit thier individual needs. If you mix hte two is will sound like Michael Moore in a farting contest with Peter from the Family Guy.
DO NOT RUN BOTH SUBS!!!!!!!
Old Jan 27, 2007 | 01:30 PM
IA_Chiefs_fan
ORIGINAL: PReal
ORIGINAL: P Zero
-P.
Dude, I'm not sure we're on the same page. I have twp 10" 4ohm subs and one 12" 8ohm sub. I wish to run the two 10" 4ohm subs at the same time.
Old Jan 28, 2007 | 07:10 PM
PReal's Avatar
PReal
Ok, thank goodness.
Sorry about the yelling, but I have seen some installs with 3 different amps and 3 different subs (sizes and specs) in the same car playing at the same time. I was trying to make sure you wouldn't fall trap to themore subs the bettermentality.
Old Jan 29, 2007 | 10:28 AM
IA_Chiefs_fan
I still have the following questions.
Old Jan 29, 2007 | 04:54 PM
PReal's Avatar
PReal
There is no better or worse between 4 and 8 ohm subs. Each has thier benefits when it comes to installtion flexibility.
Each one of your 10's is a 4 ohm svc sub rated at 200 watts rms. When wired in parrallel that gives you a total of 2 ohms resistance and 400 watts rms.
There are a variety of amps that would work, could you please give me your budget.
Old Jan 29, 2007 | 08:30 PM
IA_Chiefs_fan
ORIGINAL: PReal
For the amp I'm going to run my two 10s with, I'd like to keep it under $200. I'm fine with ebay, used or refurbs.
Old Jan 29, 2007 | 11:28 PM
PReal's Avatar
PReal
Really cheap http://ikesound.com/product-product_id/2840
Better http://ikesound.com/product-product_id/4352
Even Better http://www.woofersetc.com/index.cfm?...roduct_ID=3963
A little over budget but nice http://www.woofersetc.com/index.cfm?...roduct_ID=4619
Old Feb 7, 2007 | 11:43 PM
IA_Chiefs_fan
Thanks! I ended up with the Eclipse XA1000 to run my pair of Rockford P210S4s and an Eclipse EA2000 to run my pair of MB Quart PCE216s. Combined with my Pioneer DEH-P80MP head unit I have just over $700 invested and think I'll be quite happy with the setup. I won't get it hooked up for a couple weeks but I'll give feedback then.
