Subwoofer/Amp help needed
Old Feb 7, 2007 | 11:47 PM
  #21
PReal's Avatar
PReal
Default RE: Subwoofer/Amp help needed
That looks like a great setup for the money. I'm glad we could help.
Make sure to post an install thread with lots of pics.
Old Feb 7, 2007 | 11:55 PM
  #22
Maxwelhse's Avatar
Maxwelhse
Those are good solid equipment choices for your budget. If that's your first system its a ton better than mine was!
If you want to upgrade later, I'm a big fan/$ of the MBQ *R*CE series. They can be had really cheap on ebay if you're willing to risk used speakers. Not a ton of power handling though...
Old Feb 20, 2007 | 10:00 PM
  #23
IA_Chiefs_fan's Avatar
IA_Chiefs_fan
ORIGINAL: PReal
A little over budget but nice http://www.woofersetc.com/index.cfm?...roduct_ID=4619
So I ended up getting this amp which has a built-in clipping detector. It is running my two 10" Rockfords but I can only turn the gain up about 40% of the way before it begins to clip. So my amp has plenty of additional power I'm unable to take advantage of, right? If so, what single 10" or12" sub would be a perfect match for the amp?
Old Feb 20, 2007 | 10:13 PM
  #24
IA_Chiefs_fan
What about this? http://www.woofersetc.com/index.cfm?...roduct_id=2537
Old Feb 20, 2007 | 11:29 PM
  #25
PReal's Avatar
PReal
Please do not buy an alpine sub, give me a budget and i can guide you in the right direction.
Old Feb 21, 2007 | 12:06 AM
  #26
IA_Chiefs_fan
ORIGINAL: PReal
Around $125. I only want one sub; not a pair. Preferably a 12".
Old Feb 21, 2007 | 11:10 AM
  #27
PReal's Avatar
PReal
http://www.edesignaudio.com/edv2/pro...products_id=31
I can't remember which amp you got, but that will determine what vc configuration to get.
Old Feb 21, 2007 | 11:46 AM
  #28
IA_Chiefs_fan
ORIGINAL: PReal
I ended up with the Eclipse XA1000 like this http://www.woofersetc.com/index.cfm?...roduct_ID=4619
Will one of these 12s sound better than my two Rockford 10s? If so, which one would work best with my amp?
Old Feb 21, 2007 | 11:51 AM
  #29
PReal's Avatar
PReal
If you bought that amp, you really need to get a nicer sub. That budget is a little low but these subs are amazing for the price.
This sub would be great is a hair under $200 http://www.tcsounds.com/tc9.htm
This sub would also work really well and is $120 http://www.tcsounds.com/tc1000.htm
If you want to go really cheap $75 http://www.tcsounds.com/db500.htm
These subs share a lot of the same architecure witha lot of higher end subs. TC is actually the OEM of many of the parts seen on a lot of nice stuff.
Old Feb 21, 2007 | 02:33 PM
  #30
IA_Chiefs_fan
ORIGINAL: PReal
So if I got the $120 sub above, would it sound noticibly better than my two 10" Rockfords with the Eclipse XA1000 amp?
