Best single sub and amp for <2K
Old Feb 2, 2007 | 03:40 PM
jgorm's Avatar
jgorm
Default Best single sub and amp for <2K
I'm looking for a high quality sub / amp combo. I was originally thinking JL 12W7 (and JL 1000W) due to its massive excursion. I have a friend with one and it sounds great. Hits hard and accurate too. Its going to be a sealed enclosure (custom built by me). I'm looking for the most accurate, tight bass and spl is not a concern. It will not be a competition stereo. Small enclosure requirements are also a big plus. Please recommend some options. High quality stuff only.
Old Feb 2, 2007 | 03:55 PM
Hisss04Cobra's Avatar
Hisss04Cobra
says hiththth
Default RE: Best single sub and amp for <2K
ORIGINAL: jgorm
There is no best single sub/amp.
I need more inforamtion.
How big of a box can you build?
What's it going in?
By tight bass do you mean SQ?
Why do you want a small box?
Old Feb 2, 2007 | 04:05 PM
jgorm's Avatar
jgorm
ORIGINAL: Hisss04Cobra
How big of a box can you build? I can build any size / shape box, but it has to fit in a mustang trunk.
What's it going in? Mustang
By tight bass do you mean SQ? Yes, I like bass to sound more like a kick drum than a rap beat. I dont like "mushy" bass.
Why do you want a small box? It has to fit into a mustang trunk.
Old Feb 2, 2007 | 04:12 PM
Hisss04Cobra
says hiththth
ORIGINAL: jgorm
You have a $2,000.00 limit for sub(s) amp(s) and that's it. Or do you need all the proper wiring, etc. etc.
Old Feb 2, 2007 | 04:24 PM
jgorm's Avatar
jgorm
Yes,
I'd like to stick with a single sub and single amp to save room. I have 2 gauge wire, rca's, etc already run. Alpine 7998 for a head unit. I also have some MDF for the box.
Old Feb 2, 2007 | 06:10 PM
PReal's Avatar
PReal
XXX 12 http://www.woofersetc.com/index.cfm?...roduct_ID=4920
Diamond audio 1500 watt rms amp http://www.woofersetc.com/index.cfm?...roduct_ID=2697
Very nice. If only you had another 2-3 hundred you could afford a really really nice amp.
Old Feb 2, 2007 | 08:02 PM
seight311's Avatar
seight311
JACKHAMMER! And 20 sony amps to power it.
Old Feb 2, 2007 | 08:03 PM
seight311's Avatar
seight311
That or the XXX, or a Tumult. Zapco/Brax/McIntosh/Audioson amp. Thats quite the budget just for the sub and amp!
And those recommendations I gave you will easily fulfill it.
Old Feb 2, 2007 | 10:26 PM
Jazzer The Cat's Avatar
Jazzer The Cat
Retired Moderator
OMG, P!!! did you see the weight of that thing? I am sure it will sound great, but you will make sparks off tail pipes driving down the road
I personally would recommend Boston SPG 555. Will handle immense power and weighs in at 26 lbs.
3 3/4 peak to peak excursion, and can be rebuilt with new VC should you clip it too many times.
Jazzer
Old Feb 3, 2007 | 11:53 AM
PReal's Avatar
PReal
He wanted the best, I posted the best. I'm sure the boston is dandy, but it won't win this competition.
I guess some of the budget needs to go towards heavy duty shocks lol.
