Remote Lead thru Fuse
Old Mar 26, 2007 | 10:15 PM
tjcoates7's Avatar
tjcoates7
Default Remote Lead thru Fuse
What is the best fuse to use for the remote lead? I tried the radio fuse but the amp still stays on when the car is off. Thanks
Old Mar 26, 2007 | 11:20 PM
PReal's Avatar
PReal
Default RE: Remote Lead thru Fuse
go buy an aftermarket fuse holder and 5 amp fuse.
Old Mar 27, 2007 | 12:13 AM
seight311's Avatar
seight311
I think he is asking what wire to use for the amp turn on. It's generally the blue/(white) wire that you'll connect to the long wire that you'll run to the remote turn on, on your amplifier.
If thats not what you were asking sorry, but thats the question I interpreted.
Old Mar 27, 2007 | 01:12 AM
ttocs's Avatar
ttocs
as for which particular fuse to use i don't have a number for you. Take a voltmeter and test a fuse until you found it is off when the key is off and on with the key on. now pull the fuse and see which side is still hot with the key on. Use that side and as he said use a small fuse to protect it....
Old Apr 2, 2007 | 06:21 PM
GTstangB.F.D.M.'s Avatar
GTstangB.F.D.M.
did this in the system on my f150.. it was one of the fuses that had to do with the radio, dont remeber if it iwas the constant radio power, or intial startup or what.. but the fuse that it was connected to was a 10 amp (is that correct, amp)...
jwog666
Dec 27, 2021 08:09 PM
breaking
Oct 2, 2015 01:27 PM
kartracing87
Sep 28, 2015 11:01 PM
daytooday
Sep 20, 2015 10:55 AM
